YB valve seats height question
Old Dec 22, 2010 | 11:49 AM
Yura's Avatar
Yura
Default YB valve seats height question
Just now I got my head after rebuild. There was exchanged valve guides. Valve seats was polished with valves for new position inside guides. And I have noticed that now, after polishing, the valves is more lower inside the seats then they was before. I know that hydraulic tappets should compensate some difference of valve clearance, but I want to ask is there some limitation for valve seat height? Or may be there are some other risks related with this?
Thanks a lot!
Old Dec 23, 2010 | 07:29 AM
Yura's Avatar
Yura
I found the picture here, on PF:
This picture can explain what I mean.
As I understand X=37,5mm is measured for new head.
Currently my head has at maximum X=38,2mm for one of the exh. valve
All others within range 37,7-38,0mm.
Is this normal for use?
Old Dec 23, 2010 | 05:15 PM
Nothing to worry about.
Old Dec 29, 2010 | 09:17 AM
Yura's Avatar
Yura
Thanks tabetha, but I decided to exchange the seats - there is another problem with low quality of the custom guides which cause of valve alignment with each other. And the seats was polished according guides. Now need to reinstall new guides again and to skim seats again, so I decided to put new cast iron seats.
S3an
Sep 26, 2015 11:39 PM
Kam B
Sep 24, 2015 10:40 AM
S3an
13
Sep 13, 2015 10:01 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
cambo205
Ford Fiesta
Sep 6, 2015 07:45 PM
