cometic 3 layer steel head gasket for YB, any good?
Old Dec 22, 2010 | 09:35 AM
john_p_b's Avatar
john_p_b
Default cometic 3 layer steel head gasket for YB, any good?
just noticed woodford have some going at a reasonable rate but want a 2nd opinion before i order.
http://cgi.ebay.co.uk/COSWORTH-COMET...item35a635177d
them.
just i've seen most are 4-5 layer? i'm never going for mental power, max of 400bhp on a GT3071
Old Dec 22, 2010 | 10:07 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I would go for a WRC gasket instead personally as they are now available at sensible money.
Old Dec 22, 2010 | 10:35 AM
DAN400's Avatar
DAN400
lots of people say the cometic ones were shit, but id one on for 4-5 years with no probs at all, but as chip says for all the extra money it ll be id go wrc
Old Dec 22, 2010 | 10:42 AM
ECU Monitor Enthusiast
Cometic are fine for the power levels you are running.
As with all head gaskets, head/block must be clean and truly flat and the head bolts installed correctly and tighness rechecked after a few hundred miles.
Often enough its the installation that makes the gasket fail !
The only thing I dispute about metal head gaskets is the number of times they say they can be re-used,
IMO, you should only use them once..... !
Old Dec 22, 2010 | 11:24 AM
Chip's Avatar
Chip
I have used cometic gaskets on quite a few engines without a problem, but the way that the fire ring design is on the WRC gasket is better in terms of how its folded (I beleive that cometic's machines cant reproduce this), so with that available I would use it instead.
cometic = good enough for most applications
wrc = better and not much more expensive
Old Dec 22, 2010 | 11:39 AM
LHD220Turbo's Avatar
LHD220Turbo
i used cometic on mine and it was perfect; but i was ultra careful with the fitting of it. The head had a fresh skim and the block was check for flatness and cleaned.
this was a few years ago, but i know i looked at the wrc gasket and it was more expensive. But i dont know how they compare now price wise
Old Dec 22, 2010 | 02:14 PM
Chip's Avatar
Chip
WRC gaskets are less than half the price they used to be
Old Dec 22, 2010 | 02:58 PM
paddyrs's Avatar
paddyrs
Ł150 for a wrc one well thats what i seen it for is that a good price?
Old Dec 22, 2010 | 03:19 PM
DAN400's Avatar
DAN400
think matt lewis sells them for Ł150, i ve seen them on ebay for Ł135 but
Old Dec 22, 2010 | 03:32 PM
Chip's Avatar
Chip
Yeah that sounds about the right ballpark, try PM'ing steveboyslim though, he might be able to do them cheaper (he can with most good quality tuning items as he buys in such quantity)
Old Dec 22, 2010 | 03:35 PM
paddyrs's Avatar
paddyrs
ok thanx chip dose he do pistons and the like too? as am for a rebuild soon after i sort my gearbox out god dam 4x4
Old Dec 22, 2010 | 03:37 PM
Chip's Avatar
Chip
Yes mate, he does pretty much anything related to big power engines.
I buy nearly all my stuff off him, he is generally the cheapest anyway but more importantly unlike other people selling a lot of this stuff he actually really knows what he is on about!
He has a man who does gearbox rebuilds too for that matter (same fella Mike Rainbird uses too IIRC)
Old Dec 22, 2010 | 04:09 PM
paddyrs's Avatar
paddyrs
thats good to know chip thanx
Old Dec 22, 2010 | 04:10 PM
Chip's Avatar
Chip
No worries mate, so hard to find anyone reliable in this game so worth letting others know when you have done!
Old Dec 22, 2010 | 06:50 PM
Its good to know these expensive items are becoming cheaper.
By the time I can afford a cossie again, they should be giving them away
Old Dec 23, 2010 | 08:39 AM
CarParts Express's Avatar
CarParts Express
http://www.carpartsexpress.co.uk/Per...p-708-742-476/
Old Dec 23, 2010 | 09:07 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
I'm running best part of 400bhp on a group A fibre gasket and I touch wood I can't fault it ...cheap too !
Old Dec 23, 2010 | 11:18 AM
paddyrs's Avatar
paddyrs
Originally Posted by CarParts Express
what make is it?
Old Dec 23, 2010 | 11:27 AM
CarParts Express
what make is it?
Cosworth
Old Dec 23, 2010 | 12:11 PM
marco polo's Avatar
marco polo
ive had cometics on one of my engines never failed at all ............
the current engine is on a wrc matt lewis does them at a very good price now
Old Dec 23, 2010 | 01:27 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
......i'm running over 400 and had a st escos gasket on the car for 3 year ish.....bit better design than a normal grp A and only Ł20
Old Dec 23, 2010 | 02:10 PM
bloomy's Avatar
bloomy
did you used to own an escort cossie, and used to sit in Mcdonalds car park in trowbridge, every so often? ....about 2003
was it dark green (mallard?) or dark blue with OZ super turismos on it?
Old Dec 23, 2010 | 02:20 PM
Yeah that was mine..LOL
RUBY123
Oct 22, 2023 12:04 PM
markk
Dec 2, 2021 06:59 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
