Series 2 rst parts. Good parts not std!
Old Dec 14, 2010 | 02:27 PM
yogurtey's Avatar
yogurtey
Default Series 2 rst parts. Good parts not std!
Hello peeps, breaking my bonus turbo 2 move on 2 bigger plans.
So i have the following parts for sale.
Engine 2.0 zvh efi, std rebuilt bottom end with pistons skimmed 0.8mm. Head is efi with double valve springs piper vernier and newman solid lifters, felpro headgasket. Done a max of 1500 miles at low boost. £300 SOLD!
series 2 lsd box. £200
4 padel cluthch kit, done a max of 1500 miles at low boost. £150
airtech alloy rad with 1, 9" fan and 1, 11" fan SOLD!
grs intercooler (the pipe work on the top out let has been remade, due 2 a mupet cuttin it off at som point) £150
megasquirt ecu and loom SOLD!
series 1! fuel tank nearly new! and fuel pump £100
turbo is stage 3 t3 exhaust housing with 4x4 cossy comp housing done a max off 700 miles never seen more than 10psi it cost me £800! will take £400 SOLD!
suspension is series 2 std fully polly bushed, bottom arms swing arms antirole bars all included (everything there) £100
4x4 cossy calipers with 2wd cossy discs. SOLD!
Exhaust, stainless with lamder sensor fitting 4in outward roled tail pipe (has a dent in it were it passes the sump) £90
corvette injectors, same flow rating as dark greens (spot on 4 the megasquirt) SOLD!
steering rack max of 18months old £15
Brake compensators £20
gear linkages £30
Drive shafts £25 each
May have other little bits and bobs i havent listed. txt or call me on 07851724052.
Thanks Rob.
Old Dec 14, 2010 | 02:39 PM
stembo21's Avatar
stembo21
god dam with i had some money just spent it on chrome lol :-(
Old Dec 14, 2010 | 03:04 PM
yogurtey's Avatar
yogurtey
Never mind
Old Dec 14, 2010 | 03:54 PM
stembo21's Avatar
stembo21
Originally Posted by yogurtey
Never mind
Good luck with the sale wount be around for long
Old Dec 15, 2010 | 07:13 AM
Antti O's Avatar
Antti O
Hi
Do you have any pics about brake setup?
4x4 cossy calipers with 2wd cossy discs. £85
Old Dec 15, 2010 | 07:01 PM
yogurtey's Avatar
yogurtey
Brakes and rad now sold.
Old Dec 21, 2010 | 02:34 PM
yogurtey's Avatar
yogurtey
bump
Old Dec 21, 2010 | 10:42 PM
Jeffers_RST's Avatar
Jeffers_RST
if theres little interest in the engine, i dont suppose you would consider selling just the head would you?
cheers!
Old Dec 21, 2010 | 10:58 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
what ms is it mate? is it setup for edis or wasted spark?? also who built it?
Old Dec 22, 2010 | 10:54 AM
rstel1's Avatar
rstel1
cheers!
+1 i would be interested in the bottom end if you will split it
Old Dec 26, 2010 | 08:23 AM
yogurtey's Avatar
yogurtey
The engine i would prefer 2 leave it as 1, but i will give it a little while and see what happens. The ms is ms1 v3 as far as i know. set up for edis (all comes with it) it was from mtech so i berlive they built it.
Old Dec 28, 2010 | 03:25 PM
robrs666's Avatar
robrs666
+2 for bottom end if no one else does thanks also where are you mate ta
Old Dec 28, 2010 | 05:55 PM
yogurtey's Avatar
yogurtey
brierley hill west mids m8
Old Dec 28, 2010 | 09:45 PM
mr_joe0606's Avatar
mr_joe0606
i might be interested in the ms ecu and loom?
Old Dec 29, 2010 | 06:41 AM
yogurtey's Avatar
yogurtey
yes m8 still got it.
Old Dec 31, 2010 | 01:19 PM
martinmilne's Avatar
martinmilne
any info on box mate how many miles it done ?
Old Jan 1, 2011 | 07:43 AM
yogurtey's Avatar
yogurtey
All i know about the box is tha lad who i had it from said it was removed from a low milage s2 he didnt know how many, i have done rufly 1500 mile with this box. All spot on
Old Jan 1, 2011 | 05:48 PM
yogurtey's Avatar
yogurtey
Ecu, loom and injectors now sold !
Old Jan 2, 2011 | 06:42 PM
yogurtey's Avatar
yogurtey
open 2 sensible offers.
Old Jan 6, 2011 | 07:41 AM
yogurtey's Avatar
yogurtey
4got 2 mention b4, the pipework on the top outlet of the intercooler has been remade, due 2 sum muppet cuting it off at some piont.
Old Jan 8, 2011 | 05:07 PM
yogurtey's Avatar
yogurtey
bump!!!
Old Jan 16, 2011 | 10:01 AM
yogurtey's Avatar
yogurtey
Turbo now sold.
Old Jan 18, 2011 | 09:35 AM
Nick1479's Avatar
Nick1479
Hi pal I'm after bottom end if possible ... Thanks
Old Jan 19, 2011 | 03:37 PM
fezzielove's Avatar
fezzielove
hi pal interested in the engine is the bottom end black top or silver top as i want a silver top and my friend wants a black top so could work both ways also i can see all the efi gear on the head but is it a efi head not mfi with inlet stuck on? also were about are you?
cheers in advance pall
Old Jan 20, 2011 | 04:14 PM
yogurtey's Avatar
yogurtey
It is a silver top bottom end, and yes it is a frst head not an mfi head. Im in brierley hill, near merry hil shopping centre
Old Jan 23, 2011 | 08:04 AM
yogurtey's Avatar
yogurtey
All on ebay now
Old Feb 1, 2011 | 06:35 PM
bubs_rsturbo's Avatar
bubs_rsturbo
hi mate interested in grs intercooler posted to belfast how much cheers
Old Feb 7, 2011 | 10:35 AM
yogurtey's Avatar
yogurtey
stil got the grs, exahust and fuel tank.
bubs i bet your looking at £20 pastage on tha thanks
Old Feb 9, 2011 | 12:21 PM
Greg_D's Avatar
Greg_D
Hi mate, i'm from stourbridge
Have you still got the connectors for things like TPS, injectors etc and all the connectors for the inlet manifold (or do you know anyone with a broken shell local who i could get this stuff off?)
Old Feb 10, 2011 | 06:17 PM
rs53ash's Avatar
rs53ash
you stil got clutch mate???
Old Feb 13, 2011 | 09:33 AM
yogurtey's Avatar
yogurtey
cluthc is gone buddy, and greg, my looms sold 2. I know of a lad called ben who has loads of parts if you would like my 2 inbox you his number?
Old Feb 14, 2011 | 10:42 AM
Greg_D's Avatar
Greg_D
That would be brilliant, please PM me
Old Feb 19, 2011 | 04:50 PM
yogurtey's Avatar
yogurtey
Greg 4 sum reason it wont let me onbox you, so if you inbox me il reply 2 it
Billy_RS
16
Oct 11, 2025 09:41 PM
markk
Dec 2, 2021 06:59 PM
155lee
14
Aug 22, 2015 12:15 PM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
