Focus 1.6 - 2.0 Duratec turbo
Old Dec 12, 2010 | 07:08 PM
Gaz 88's Avatar
Gaz 88
Default Focus 1.6 - 2.0 Duratec turbo
Hello everybody, Had my car for two years now but never got round to putting a thread up here so here we go!
Started off as a 1.6 edge with a gearbox problem
Then it got stripped
My rs engine came out of the shell that dingla had think someone else on here has got a thread about it
Old engine out
Car had the full rs engine and full rs wiring looms ecu's, fans, mounts, chargecooler setup, diesel TDCI Driveshafts, st170 hubs knuckles front brakes, full st170 rear beam and disc setup, gaz coilovers.
st170 rear beam
Found a new fun plate for the car
I then got a full mongoose exhaust fitted
Standard interior with rs clocks, stack boost guage, rs centre console and scanguage
Then got it rr at 250bhp
Got my arches rolled and focus rs fitment comp mo's on, And tidyed up the front bumper with ducts where the fogs used to be.
more updates soon!
File Type: jpg
Old Dec 12, 2010 | 07:10 PM
DazC's Avatar
DazC
I thought you meant an actual Duratec turbo when I read the title, not a Focus RS Zetec engine! I was hoping to see a Duratec turbo conversion.
Old Dec 12, 2010 | 07:13 PM
Gaz 88's Avatar
Gaz 88
Then moved the battrey to the boot
Then got a fms manifold and forge actuator and ran direct. RR at 282bhp
Then i took this pic and thought it looked discusting so the rebuild statred jan last year!
Old Dec 12, 2010 | 07:16 PM
RichieST's Avatar
RichieST
Awesome little sleeper
Old Dec 12, 2010 | 07:24 PM
Chaz888's Avatar
Chaz888
sweet dude nice, trick but not in yer face!
Old Dec 12, 2010 | 07:25 PM
Gaz 88's Avatar
Gaz 88
Started buying a few new bits!
Custom size K&N filter
Pro alloy 70mm intake pipe
Filter made up (needs the 45 degree hose cutting)
Primary Designs inconal manifold (ceramic coated)
Focus RS Grill (needs painting grey)
Womble alloy thermostat housing and new thermostat and gaskets
Few roose hoses for coolent and Air to Air
Vibra technics LHS and RHS engine mounts
LHD reverse light
Pro Alloy Rad
more updates soon!
Old Dec 12, 2010 | 07:33 PM
Gaz 88's Avatar
Gaz 88
Sent some bits for powdercoating while they were off
Pro alloy custom intercooler
JohnFRS hybrid and custom Womble bracket to turn the compresser housing
Us rears
Roose coolent hose set
Blueflame decat and flexy
Zircotec coated
more updates soon!
Old Dec 12, 2010 | 07:37 PM
Gaz 88's Avatar
Gaz 88
While everything was out thought i would remove some unused brackets and give the inner wings a lick of paint
The result! not bad out of a ratle can!
Old Dec 12, 2010 | 07:42 PM
Gaz 88's Avatar
Gaz 88
Then started to fit things back up!
Manifold fitted!
On all the aftermarket air to air kits the power steering cooling pipes have to be bent up and the fitment isnt very good so thats why i decided to make my own!
No bent pipes here!
Old Dec 12, 2010 | 07:44 PM
Gaz 88's Avatar
Gaz 88
I then decided to Modify the coolent kit (the hose to the coolent pipe on top of the radiator now points down) This will now run across the bottom of the rad instead of the top near the mega hot manifold.
Old Dec 12, 2010 | 07:46 PM
Gaz 88's Avatar
Gaz 88
CFM Lower mount
Old Dec 12, 2010 | 07:49 PM
Gaz 88's Avatar
Gaz 88
I changed the radio surround as the old one had scratches on it and replaced the old aircon switch with one out of a focus LX model as i have stripped the ac off it (well pete did)
Old one
New one
Turbo fitted and alloy womble stat
Old Dec 12, 2010 | 07:52 PM
Gaz 88's Avatar
Gaz 88
Got a new reducer hose from graham at carpartsexpress as i thought the compresser housing outlet was 60mm
Also got this off ebay going to make something out of it for trackdays as thats where my air filter will sit eventually
And my new steering wheel and lifeline group n snap off boss
Turbo oil feed and returns!
Old Dec 12, 2010 | 07:53 PM
Gaz 88's Avatar
Gaz 88
Just been and picked my pro alloy intake tube and maf holder up from the powder coaters! Everything else is black so thought i should get this done
Also got the turbo coolent feed and return painted black and fitted to day along with a few other bits.
Old Dec 12, 2010 | 07:54 PM
Gaz 88's Avatar
Gaz 88
Pro alloy rad and powder coated fan holder made up ready to go in
Old Dec 12, 2010 | 07:55 PM
Gaz 88's Avatar
Gaz 88
Got the grill painted and bumper fitted!
Brian's Avatar
Brian
Looks awesome mate
Brian
Gaz 88's Avatar
Gaz 88
Old Dec 12, 2010 | 07:57 PM
Gaz 88's Avatar
Gaz 88
Got the headlights in and also the filter setup in
Old Dec 12, 2010 | 08:00 PM
leigh-k18's Avatar
leigh-k18
wow now one of my fav focus on here i love them in the colour and all the work you have put in is a great credit to you mate looks stunning!
Ginger Will's Avatar
Ginger Will
nice sleeper.
Old Dec 12, 2010 | 08:01 PM
Gaz 88's Avatar
Gaz 88
Made a holder for my new blitz sbc id3 boost controller out of one of the air vents
Took me about 6 hours
New steering wheel and boss
Started to mock up the air 2 air pipes aswell!
Old Dec 12, 2010 | 08:06 PM
Gaz 88's Avatar
Gaz 88
Cfm lower mount fitted
Air 2 air pipes mocked up in plastic and sent to pro alloy!
These have been made and were with the powercoater yesterday so expecting them anytime,
Also got a lenght of 25mm roose hose to fit my dv up near the elbow and some high temp ducting,
can see the alloy bracket that i made for the boost controller solinode to keep original mounting points.
The two funnels in place of the st170 fogs (pipe not fitted on the pic tho!)
It also runs up virtical so no chance of any water getting up to the filter!
Old Dec 12, 2010 | 08:10 PM
Gaz 88's Avatar
Gaz 88
Air to air alloy pipes back from pro alloy
Also moved the dv upto near the throttle elbow!
Few shots of the finished bay
You can see the duct going upto the air filter in the pic below,
Old Dec 12, 2010 | 08:11 PM
Gaz 88's Avatar
Gaz 88
Got a stainless steel pipe to replace the one in the drivers side wheel arch thats prone to corrodeing.
Old Dec 12, 2010 | 08:14 PM
fiestaturbo1984's Avatar
fiestaturbo1984
looks awesome mate
Old Dec 12, 2010 | 08:18 PM
Gaz 88's Avatar
Gaz 88
Got some alcons off ebay off a jag for a bargin price, 6 pot monoblock. Looked a bit worse for where when i got them.
Then used nitromores to strip them (Not an easy job think it was concrete paint)
And removed all bleed screws and bridge pipes.
Then got an engineer to mill the face smooth and lose the IR. Cheers womble top job pal
Then i masked both of them up (all pistons and mounting faces)
After 6 coats of Bright red VHT Engine enamel
Got some custom size alcon stickers (off dmb graphics) very good service aswell
They then looked like this
Very happy with them they just need a few coats of VHT gloss clear engine enamel which i will do tomorrow
With all new bleed nipples, dust covers, bridge pipes and pad retaining clips off ears motorsport it still works out loads cheaper for the two than buying just one new
Just waiting for a hub to be sent to martoonthe i should recive my ap discs and bells and brackets.
Old Dec 12, 2010 | 08:22 PM
erjones's Avatar
erjones
Like it! love the looks of the ST170 but with a surprise under the bonnet, good combo
Old Dec 12, 2010 | 08:50 PM
TimC's Avatar
TimC
Wow, fantastic build.
Old Dec 12, 2010 | 08:55 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
A very impressive build there.
Old Dec 12, 2010 | 10:11 PM
Big-Dan's Avatar
Big-Dan
I like this alot
Big-Dan.
Old Dec 12, 2010 | 10:39 PM
ScORTED's Avatar
ScORTED
Project Money Pit
Sick, would have loved to have done this to my focus... respect!
Old Mar 8, 2011 | 06:51 PM
Gaz 88's Avatar
Gaz 88
Got some ds3000's for the calipers
The pads are massive so should stop me
discs and bells and brackets should be arriving soon!
New wheels turned up today
A fire extinguisher turned up for the 30-130 day!
Also oil, oil filter and brake fluid turned up for it
Bridge pipes, Brake retaining clips, bleed nipples and bleed nipple covers turned up so got the calipers finished
And The best bargin mod for a focus Ł10
Old Mar 8, 2011 | 06:54 PM
Gaz 88's Avatar
Gaz 88
Discs, bells and brackets turned up today and petes going to sort the hoses out
Also got an alloy cam cover off steve7786 (cheers mate) which is at pro alloy getting a -10 fitting welded on so I can aeroquip my rocker breather when I fit my catch tank,
Old Mar 8, 2011 | 06:56 PM
Gaz 88's Avatar
Gaz 88
Finally got tht 1.2's wrapped in A048's
Was up at petes last night and its running and the brakes are fitted! The Td's need a 2mm spacer then they will be fitted then its just set up the boost controller and actuator
Old Mar 8, 2011 | 07:01 PM
Gaz 88's Avatar
Gaz 88
A few recent pics
Set up the boost controller but having a bit of a problem with channel 4 so going to try turning the pre load up abit other than that it might need a uprated pump!
Nearly there now tho!
:thumbsup:
Old Mar 8, 2011 | 07:12 PM
NEIL A's Avatar
NEIL A
Brakes look good what size disk did you end up using with the Alcons, think im going to strip and paint mine after seeing your pics.
Old Mar 8, 2011 | 07:13 PM
CraigoScott's Avatar
CraigoScott
that looks amazing!!! quality sleeper! what suspension is it running?
Old Mar 8, 2011 | 07:18 PM
Gaz 88's Avatar
Gaz 88
There a 362/32mm AP Racing disc, They have come up mint im well happy with them!
Its running Gaz coilovers but they might soon be changed for KW V3's
Old Mar 8, 2011 | 07:36 PM
Adam31's Avatar
Adam31
Waiting on my fast ford..
This is an awesome build, so neat and tidy, just the way it should be. Should be nearer 300bhp now I would have thought. Love the brakes.
