lowering a p100 how???? and stud conversion???
hi i've just bought a pretty tidy p100 but want to do something smart with it how low can you go while still using the leafs and what parts are needed to drop it also is it possible to get an engineers to flatten the springs at all? also what is the best way to go about lowering the front end looking to lose alot of height if possible also what is the easiest way to go abouts converting to 4 stud wheels cheers sean.
The easiest way I done mine was normal sierra legs on the front and a mk3 Capri axle on the rear then just shorter springs on the front and I made some lowering blocks for the rear out of box section
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
