S2000 Mk2 Escort breaking, seats, Aeroquip etc..
Right full update of whats available right now :
Honda F20C S2000 engine, complete with new TWM 52mm throttle bodies, new RED dry sump kit and a new TTV billet flywheel.
The dry sump pan allows another 100mm of clearance over the standard sump pan, its uses a Pace pump which is attached to the cast sump pan.
Also comes with wiring harness, 6 speed gearbox, starter motor, stock clutch and flywheel, exhaust manifold
The engine is low mileage, removed from a Westfield and then had all the new parts added to it, the parts alone were near to £3500 and the engines fetch between 2-3k so I have priced it fairly.
The throttle bodies unlike the Jenveys are complete with carbon trumpets, linkage, tps sensor, fuel pressure regulator and injectors so require nothing extra, the throttle cables are also included.
Also included is a brand new Pipecross air filter with a undrilled back plate.
£5000 ovno
Brand new Cobra Monaco seats in red, one still wrapped as delivered.
£350 new from Demon Tweeks, £300 ono
Perspex door windows with sliders, supplied by P4P £120
Aeroquip :
Mostly new, mixed manufacturers but mainly Earls iirc.
Most of the fittings have been fitted to hoses and have been installed in the car so have the odd scratch on them but have not had any fluids run through them as yet. These are provissionally for sale, I may yet keep them for my new car unless someone wants to make me a sensible offer on the lot
2 x -12 male to male joiners
2 x -12 90 degree non swept
3 x -12 90 degree swept
2 x -12 45 degree swept
2 x -12 straight
1 x -10 straight
3 x -10 90 degree swept
14 x -6 straight
3 x -6 90 degree swept
1 x -6 45 degree
1 x -6 120 degree
1 x -6 90 degree non swept bulkhead fitting
4 x -6 bulkhead fittings
8.5m of -12 hose in 3 lengths
1.5m of -10 hose in 2 lengths
Several metres of -6 hose in all sorts of lengths
This all came out of a Mk2 Escort so anyone doing a dry sump and fuel install would need all of the above if the dry sump tank is in the boot.
I will add more when its available.
£5000 ovno
Aeroquip :
2 x -12 straight
1 x -10 straight
14 x -6 straight
1 x -6 45 degree
1 x -6 120 degree
Oct 9, 2015 07:38 PM
