for sale, ZT bits / uprated Gbox / mk3 fez bits
right as most you know, you often change your mind while doing a project
so decided its about time i sold some bits,
can get pictures if needed,
- zetec turbo management (looking to keep as bundle)
ofab ecu with ahmed bayjoo chip mapped for zetec turbo (the spec of the engine was t34/ ahmed injectors around the 300bhp area)
ofab engine loom which runs a zetec turbo to go with the above management
2.5 bar map sensor
edis module
SOLD
- ian howell's rover inlet manifold originally made for paul johnsons first ZT, (its the bigger of the two available)
has ians zetec adapter plate, so its ready to bolt on
comes with fuel reg and fuel rail
FRST iscv
all you need is a FRST throttle body and injectors (was used/mapped on the engine management above)
SOLD
- cts stage 2+ bc gearbox
does'nt have a quaife atb diff anymore as i used it on a different box of mine,
so still has uprated ib5 bearings and shot+peened gearset
currently looking for an rs turbo viscous diff to put in
inspected the gears and selectorsfor any signs or wear and all look good,
brand new ford gaskets used when put back together
if this still had the quaife in, it would sell for £850
so to keep it fair i'm looking for £650
- gear selector originally from my Si 16v
rebuilt with the new ford parts including rod and stabilizer
had the main gear stick shortened by 20mm
SOLD
- brand new aftermarket bc gearbox starter motor
SOLD
- zetec rear engine mount
in good used condition
£20
- power steering pump from an Si 16v
SOLD
- alternator bracket/ powersteering pump bracket/front engine mount from my fiesta si 16v
in good used condtion
£25
- oil cooler take off plate with thermo stat control for zetec engine
SOLD
- bc gearbox shim
refurbed and sprayed satin matt black
£20
- series one silvertop cam cover
been sprayed evo electric blue and embossed parts polished then laquered ( dohc/ford)
£40
- mk3 bonnet with subtle euro/half badboy
would need spraying to your colour, no dents or bad press marks
£40
2.5 bar map sensor
edis module
SOLD
FRST iscv
SOLD
SOLD
SOLD
£20
SOLD
£25
SOLD
- bc gearbox shim
£20
£40
£40
JoeyBoyden
Jan 4, 2024 02:36 PM
rog
Sep 4, 2015 12:10 PM
