Heated Windscreen Relay
Old Nov 30, 2010 | 02:24 PM
hullguy1974's Avatar
hullguy1974
Default Heated Windscreen Relay
Hi can anyone help tell me where i would locate an escort mk7 heated windscreen relay as my haynes manual is useless at telling you simple things like this.
Thanks
Old Dec 1, 2010 | 12:25 PM
martysmartie's Avatar
martysmartie
It is actually a MK6 Escort, check the fuse boxes, it may be a special "relay" with a timer built in and so will taller (Possibly pink as it was on older cars), if not it may be awkward like the Sierra and be behind the dash. If ECU controlled it may be a conventional relay.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
