L6 vs L8 ECU
Old Nov 28, 2010 | 05:43 PM
kaisersolsay's Avatar
kaisersolsay
Default L6 vs L8 ECU
What's the advantage of using an L8?
I need an ECU for my 4x4 Cossie Cortina project and not sure if I need an L8 or not.....L6's are cheaper as you know.
Do I need to use an L8 for the 4x4 lump? I have a L8 MSD chip for my set up...will this fit in an L6?
Cheers!
Old Nov 29, 2010 | 07:58 AM
The chip will only fit the ecu type it was designed for, ie L8 chip won't work in a L6, unless you want AL LC then a L6 would do the job perfectly, but you'd need a new chip, so do some sums and work out what's cheapest in the long run, you may decide you want after market after adding up the exorbitant costs.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
