se rolling road day 19th june BOOK NOW
From: learnin to build a yb lump properly in dennis's garage
nikki and i was talking about this last nite who would be up 4 it the previous one organised by dan visteon was a huge success so put your name down if there is enough interest we will get it arranged
more than likely to be held at engine advantages at witham unless anyone has any other suggestions?
yes it is a 4wd rr and it will handle pretty much anything on this bopard think the rollers can handle up to 600 bhp per axle or somthing like that
ill come and watch
cars too rattly on idle, imagine the noise the fooker will make when on the rollers
mind id like a big bhp power graph
, wonder if i would get higher than me 352bhp one i got
mind id like a big bhp power graph , wonder if i would get higher than me 352bhp one i got
pugo
pugo
it would be fine aslong as they checked the fueling
but i wont use a set of rollers for my car
, think my arse dyno is enough for me as i dont use the power i got anyway
15 quid for a A4 sheet of paper aint what im into, the day out with aload of car mates is better
so i will come to watch
good thing about some rollers as they lower the load to get a bigger bhp figure ( not mantioning names to start trouble !!!
as rollers are a set weight and and cannot be altered, its a lot easier to do it with the software than with carefully machining the rollers
i do not want to sound stupid here, but why is your car running lean under load, i thought you had just had it set up?????????
and no before anybody asks this is not a dig at anybody, i am just curious??????
why not turn the boost down a bit????? or the fuel up a bit???? or is there a mechanical problem elsewhere ????
pugo
i lived in witham till i was twelve and always go down there to visit my nan so im defo coming..... sold the rs 2000 so i willget my self a new car and see if its worth putting it on the rollers!!!!!!!!!!!
)stu was gona turn it down but due to way i do drive he said he dont mind leaving it as i dont drive like rsgus
he also took the time to advise me of a few mods to suit my driving style, fit standard cams, standard head, t3 hybrid and i will prefer that spec more
, he was being serious as tbh i have never had my cosie over 135mph and the times ive had ot over 110 i can recall all of em, its that little
hope that helps you to understand
but as its holdng more boost and the cams ect it holds just over 25.5psi allthe way up the rev range and peaks at just over 27psi
so its a very very strong car that suits me as i dont rev the bollocks off it
he also aedvised a live map to make it spot on and he could do a bit more but as it was i got a chip off him and he also had to add extra fuel to the map due to the cams and head allowing more air instead of turning the boost down as it was running lean
thats why i will gladly drive all that way and wait 3 moinths on his waiting for a live mao as soon as the niggly prblems are sorted out on my car
thankyou for clarifying that,
however i think your fookin mental for leaving it like that and if i was stu i would have beat you with the soggy end of the workshop mop
for even asking
pugo
I never doubted that for a second, as you had told me at S/E PF meet how happy you were with him/the car
for even asking
pugo
if i wasnt happy with the service i wouldnt have a MSDevelopments sticker on me car and clean it once a week
