fitting pro alloy intercooler to S1
just got my new intercooler today,
just a question for people who have one or know how to fit it,
it sits infront of the radiator, but i dont know if it bolts to original
holes or new ones have to be drilled,
it is a pro alloy, the one with 2 fans on it.
cheers
cheers
bolts too 2 original holes on the front panel under the top of the front panel u will see 2 holes.was a bit of a pig to fit i have a pics
as u can see from the pic theres an oblong shaped hole just above the hose that connects the intercooler to the 180 bends just below that hole are the fixing holes i presume, theres 2 of them and i had to cut my front panel which i wasent keen on but it is a bigger item bearing in mind i had the rad as well.
the front grill will have to be modified to due to the cut out,this may not be req on your car however i wanted to make sure the car could be put back to normal easily if req, so i used an old grill and cut it and split the front panel with a junior hacksaw and bent it up. then if req i use my spare grill bent the front panel back down 2 mins with the mig bit of touch up paint and back to standard
the hoses i presume u have to supply yourself cuz i didnt get any[/img]
track.focus'd
Aug 12, 2015 05:53 PM
