Cosworth YB "Knock Sensor"
Old Nov 24, 2010 | 05:08 PM
Hoogi's Avatar
Hoogi
Default Cosworth YB "Knock Sensor"
Can anyone explain to me what and where a "Knock Sensor" on a Cosworth YB fits and what it does ?
I'm running a P8 ECU which has one of the Motorsport Development Chips to suit a Standard Compression Ratio, T34, Siemen 55's and a Wasted Spark / Coil Pack set-up.
Many thanks..........
Old Nov 24, 2010 | 05:26 PM
martysmartie's Avatar
martysmartie
Only 4x4 and Escos have knock sensors, it detects detonation and retards the timing.
Martin
Old Nov 24, 2010 | 05:34 PM
Hoogi's Avatar
Hoogi
Marty,
The spanner in the works is it's in a MKII Escort.
RS500 Blocked Engine........do I need this item and where does it go ?
Many thanks again for the reply
Old Nov 24, 2010 | 05:45 PM
martysmartie
RS500 never had one, on 4x4 and Escos it's at the bottom on the right hand side of the block.
Martin
Old Nov 24, 2010 | 07:41 PM
cozzy jeff's Avatar
cozzy jeff
this is where it goes mate.undo that bolt on the left and screw your knock sensor in there.
Old Nov 24, 2010 | 07:44 PM
Paul_RS's Avatar
Paul_RS
Thats not where it goes That bolt goes into a water way! The proper hole is right at the bottom of the block.
Old Nov 24, 2010 | 07:48 PM
The Youth.'s Avatar
The Youth.
as paul has said it goes into that threaded hole under the breather outlet
I once took that other bolt out by mistake when fitting a breather I soon knew my mistake when I got wet!! lol
steve
Old Nov 25, 2010 | 04:29 PM
cozzy jeff's Avatar
cozzy jeff
ahhh i stand corrected.
Old Nov 25, 2010 | 06:18 PM
Hoogi's Avatar
Hoogi
Many thanks Gents,
So, what's the issue if I don't run a Knock Sensor ?
My Engine is spec's as follows, so wondering if people do without ?
RS500 Block (Small Cores)
Long Studded
4x4 Head
H-Section Con Rods c/w Group A pocketed Pistons
BD14 Inlet & BD10 Exhaust
T34
Collins Actuator
3Bar Map Sensor
Siemen 55lb Injectors
Big Wing & Baffled Sump - High Pressure/Flow Oil Pump
Wasted Spark (Coil Pack)
P8 ECU - Closed Loop - Motorsport Development Evo Chip
I'd like around the 350BHP mark - again not sure if this info helps with you answering the question ?
Cheers everyone
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
