MG ZT
Evening All
Anyone know anything about em?
Reliable enough???
They seem cheap and spacious enough for a bit of a comfortable motorway cruiser run around type car.
Need somet late model ish and nice ish looking
What do people think?
Reliable enough???
Decent cars mate. I've had one for the last year and the only problem i've had is a faulty coolant cap. Mines the V6 and apart from being a bit thirsty i can't fault it.
Are you after a petrol or diesel?
We had some in the rental fleet when I was valeting - they took the abuse pretty well. I know of a couple of people who had HG problems with the 1.8T, which is a shame as it's the nicer drive around town IMHO. If going for the V6, it has to be the 190 model - much better alloys!
They did a '+' spec, which included Sat nav / TV. Sadly despite ordering some ours all arrived without so can't comment on how good the nav was.
Bear in mind that standard tyres are a something like 225/35 so you'll want to check current prices.....and the state of the roads around you! (Plus side of being in Shirley now - less pot holes
Economy better on V6 than 1.8T, reaslistically.
HTH
Chris
HTH
Chris
Our V8
Not counting!
The Rover 75 and ZT range had a lot of design input from BMW and as a result are quite good cars (75 is a bit boring though), lots of the parts are actually very similar and in some cases the same as BMW.
We also had 1.8 N/A auto-box 75's on the fleet which were proper slow!! Also for some reason the interiors seemed better screwed together on the ZT. No idea why that would be....
Chris
Chris
Chris - I live almost over the road from you between the pub n the shops.
Cheers for the comments guys
I have been looking around and seems all good - anything I should know about common probs wise?
Why does the lower spec car have the better wheels?
Petrol V6 for me - V8 for 100+ miles a day would kill me.
Had an 05 plate ZT-CDTi 135+ and it was superb.
Only sold it as my Brother made me a stupid cash offer I would of been silly to refuse
Best thing was, I only gave £3700 for it, one owner, Full history, everything included and was a cracking motorway cruiser with the BMW M47 diesel engine
Airbag light - usually just the wiring under the seat. Easy enough to fix.
Thermostat housing - it's in the middle of the V and can split. It can make the car seem like its got head gasket issues. It's not the nicest of jobs.
Inlet - Motors fail and can often cause a rattle. If it's the actual manifold thats failed it can be costly.
Other than that and making sure it has two keys i can't really think of anything. Others may have some ideas.
Keys are not too bad, they're around £110 and will open the car (manually) and allow you to start and drive away... They need programing to make remote central locking work but thats only about £40.
