getting rid of rear load sensing valves on mk3 fiesta
hey up i wanna bin off the rear loads sensing valve off on my mk3 rs1800 can i???how do i do it what needs to be modified to compensat??or do i just chop them out and be done with it??
because its on its arse the front bakes dont wanna work much so wanna bin um off,,ive tried and tried to adjust the dam thing with no joy
cheeRS in advance
cheeRS in advance
You need some form of adjustment for the rear brakes esp on a light car like yours, you can fit a bias valve in line to the rear brakes then take out load valve, but would need to experiment to get best setting brake balance wise.
Red_bull
Aug 9, 2015 08:34 AM
