best inlet for a cosworth
Old Nov 21, 2010 | 08:27 AM
rsmark86's Avatar
rsmark86
Default best inlet for a cosworth
right i picked up my new 3dr cosworth the other day....
and took it for a rolling road session and it was ment to be mapped to 2.2bar but would only hold 1.6bar but made 414bhp and 416lbs and made the torque before 4k so is a realy lively engine concidering the gt35....
then we found that it has a hole in the top boost hose the size of a 5p so is dropping 0.6bar and will only boost to 1.6 and hold 1.5bar....
so i need a boost hose for a 70mm intercooler to gt35 turbo ?????? who does them
and i want to put a nice inlet on it as ive been told by alot of tuners with the boost leak fixed its a 500+ car ....
how much difference does a spacer make or should i just get a big plenum
cheers
Old Nov 21, 2010 | 08:28 AM
12_Second_rst's Avatar
12_Second_rst
pics mark
Old Nov 21, 2010 | 08:33 AM
RS SHAUN's Avatar
RS SHAUN
Roose motorsport for your boost hose mate!
Old Nov 21, 2010 | 08:40 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have a 70mm intercooler to Standard TB hose
Roose all the way for custom hoses, very very helpful and quick delivery.
What inlet manifold have you got at the moment ?
Steve
Old Nov 21, 2010 | 08:41 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
A Small Turbo Escos inlet or Heart inlet for 500+
Steve
Old Nov 21, 2010 | 08:44 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Plenty of Inlets out there.
RS500
Swedish
Hart Plenum (Bluesprint)
SCS Custom Inlet
I went for swedish
Old Nov 21, 2010 | 09:56 AM
Roosie's Avatar
Roosie
Steve
Been trying to look for st cosworth inlet for ages keep getting sold when I see them
Old Nov 21, 2010 | 10:28 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Got one on mine
Steve
Old Nov 21, 2010 | 10:36 AM
Roosie's Avatar
Roosie
Got one on mine
Steve
why you got one yours dont make 500hbp
Old Nov 21, 2010 | 10:43 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Every little thing helps
Its not far off anyway
Steve
Old Nov 21, 2010 | 10:50 AM
Miller 3's Avatar
Miller 3
First off who tunes your car?
but as said get your hose from roose motorsport (You sure you dont need a 76mm hose?) http://www.roosemotorsport.co.uk/images/hy7.jpg
But with an engine of that spec it sure would benefit from a new manifold
if i didnt run a genuine swedish id have got a new heart plenum myself
once yours is done you should see 580+hp imo
Old Nov 21, 2010 | 10:51 AM
J1mbo's Avatar
J1mbo
B1mbo
do you know the spec of his engine doug ? as to see 580 genuine bhp on a gt35 is a decent engine
Old Nov 21, 2010 | 11:03 AM
Miller 3's Avatar
Miller 3
im only guessing hear at this point bud, but who would put a 35 on a standard engine? i just dont see anyone doing that? or am i wrong lol... but as said surly a 35 is at least a 560 upwards turbo
And genuine hp... is there and other kind??? lol
Old Nov 21, 2010 | 11:08 AM
J1mbo's Avatar
J1mbo
B1mbo
yes but dont want to get jumped on so wont bother lol !
well youve seen the trend lately everyone not bothering with ported head and no cams, so to see 580 it should have both of the above
Old Nov 21, 2010 | 11:20 AM
Miller 3's Avatar
Miller 3
I just dont see why someone would go "I want 550+hp.... i know il put on that lovley big shiney turbo" ..
but then again thinking about it i have this one friend who you just cant talk too, he just buys some right old tat and thinks his car will make 10 million hp
but if I was specking a 550/600 build id go 35 or equivalent
Old Nov 21, 2010 | 11:23 AM
J1mbo's Avatar
J1mbo
B1mbo
There are plenty of people on here that have done that.
Old Nov 21, 2010 | 11:46 AM
Staffi's Avatar
Staffi
So what kind of power does the Standard 2wd one cope with??
Old Nov 21, 2010 | 11:47 AM
rsmark86's Avatar
rsmark86
the car is as follows
fully rebuilt 200 block bottom end fully ported and worked head with custom grind cams..... engine built by grace engines (this was his own car)
ported inlet but with no spacer ect
gt35 external waste gate and screamer
1000cc injectors
autronic sm4 with wasted spark set up (twin coil packs) mapped by mark shead
70mm intercooler
anti lag
and the list is massive
its mapped for 2.2bar boost but due to the boost leak only holds 1.6bar....
but i realy like it with the leak as when it was 2.2bar is was scary lol and now its just rapid with loads of grip....
but stuff it im going for an inlet and remap from mark and he said the limit is 580bhp before i need an exhaust manifold change but i just want a nice 520/550bhp....
it was mapped at 2.2bar and has seen 520bhp before so just need a boost pipe...
Old Nov 21, 2010 | 11:50 AM
rsmark86's Avatar
rsmark86
the engine spec is good as it is better to drive in terms of response than my old t34 car...
starts making boost at 2600rpm and is at full boost before 3500rpm (when its not leaking lol)
and with the leak made 416lbs at 3850rpm and held on those numbers past 6k
will sort some pics soon as its got a wee dent in it due to the last owner spining the car at castle coombe so rather than just repairing im having the whole car done.... then some comps and ap brakes
Old Nov 21, 2010 | 11:53 AM
Staffi's Avatar
Staffi
Mark, what Box & Diff are in the car??
Old Nov 21, 2010 | 12:16 PM
KSA-Cossie's Avatar
KSA-Cossie
What price is a st escos inlet and a hart one ?
Old Nov 21, 2010 | 12:25 PM
J1mbo's Avatar
J1mbo
B1mbo
1000cc injectors
70mm intercooler
anti lag
Seems a decent spec it should see way over 500 as Doug says but obviously don't now how good the head is
What exhaust manifold do you use ?
Old Nov 21, 2010 | 12:33 PM
12_Second_rst
pics of car or its not real ;p;
Old Nov 21, 2010 | 01:29 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You still didn't say what inlet your using at the moment.
Steve
Old Nov 21, 2010 | 01:30 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You will also want the TB from the ST inlet as its bigger, i think they go for about Ł200
Hart inlets are around Ł450
Steve
Old Nov 21, 2010 | 01:34 PM
JamesH's Avatar
JamesH
I have a 14mm spacer if you need it, don't need to chop about the fuel rail lugs then either
Old Nov 21, 2010 | 01:41 PM
Staffi's Avatar
Staffi
I'll quote myself then....
Anyone ??
Old Nov 21, 2010 | 01:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Anyone ??
Think its about 400 Pete, then a 4x4 upto around 450, then the ST Escos above that.
Might be talking bull$hit as well lol
Steve
Old Nov 21, 2010 | 02:01 PM
Miller 3's Avatar
Miller 3
My advice would be that if you only want 520/550, id downgrade the turbo to a GT30:76 the same as mine. you will find quicker spool up just not the top end power that the 35 is capable of. although that 35 dose seem to spool rather well if that is correct?....
and id also check the inter cooler before you order a hose as the 70mm you put is most probably how thick it is as apposed to the end pipe size, there more likely to be either 63mm or 76mm
Id even hazard a guess that you are on a 2wd ex manifold as there is no way you would get that power from one of the 4x4 variety!!
Old Nov 21, 2010 | 02:15 PM
pig's Avatar
pig
i think it is a tubalur manifold on this car but runs a standard t5 gearbox and im sure a none standard motorsport diff.it was fucking fast to be fair after mark mapped it
Old Nov 21, 2010 | 04:05 PM
rsmark86's Avatar
rsmark86
standard rebuilt box and motorsport diff
Old Nov 21, 2010 | 04:11 PM
rsmark86's Avatar
rsmark86
its got a modded manifold with spacer plates to fit gt35 and tial (massive) wastegate with screamer pipe and MAD have said it will do 580bhp but the inlet is standard but fully port matched to the head....... so need to uprate...
ive been quoted for the hart inlet larger and remap Ł700+vat fitted and remapped and have been told it should see 550bhp with it...
but the gearbox needs uprating first so recommendations welcome please been looking at cts big tooth with uprated folks and a reyland hydrulic clutch set up
pig knows the car it was his mates and as he says when it runs the 2.2bar its rapid
Old Nov 21, 2010 | 04:37 PM
Miller 3's Avatar
Miller 3
What is your budgit for the box? if you want to do it cheap, maybe use your box till it brakes, then get a quaife stright cut gear set for around a grand+ fitting or you can get a helical TKO from the states... Reyland can sell you this on the shelf for around 3/3.5K
plenty more if you want to spend 10K+ but i doubt it
Old Nov 21, 2010 | 04:42 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i have the cts box on one of marks 500 set ups the box mad ade also has, hasent let me down and i beleave its still going stronge in ades car so its more than proven in road use with the power he has lol mine cost me about 1300 with no vat exchange
Old Nov 21, 2010 | 04:56 PM
rsmark86's Avatar
rsmark86
cheers guys well the box i want if i got a cts one is with the uprated selector folks but i realy want a straight cut jobbie so might look at a gearset and for some one to fit it
Old Nov 21, 2010 | 04:59 PM
gibbo frst's Avatar
gibbo frst
Theirs a glebe t5 i'n the parts section on here and on eBay. Mr.worths saff breaking think it's new too.
Old Nov 21, 2010 | 05:02 PM
rsmark86's Avatar
rsmark86
2k aswel lol ive looked at it and if i can get the money i will have it
Old Nov 21, 2010 | 05:07 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Inlet? 450 no problem.
Old Nov 21, 2010 | 05:17 PM
Roosie's Avatar
Roosie
my 2wd inlet makes 397bhp on my 2wd but thinking of getting a 4x4 inlet and spacer to see if i can gain power at same boost levels
Old Nov 21, 2010 | 05:19 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have a 4x4 inlet for sale
Steve
