cossie 4x4 pissing oil through the head
Old Nov 20, 2010 | 09:04 AM
derekd's Avatar
derekd
Default cossie 4x4 pissing oil through the head
wife was using my cossie the other day called me and said it was smoking bad :-( I thought the turbo had gone changed it no luck still the same lot's of oil through the head into turbo ,intercooler, exhaust and i mean a lot of oil :-( so now i've took the engine out and stripped it down pistons and rings look fine sump pick up was full of shit and the bottom of the sump.The head was showing that oil was pissing through 3 of the ports ? Checked the bores for cracks and were fine.Now got me thinking the head has a crack but couldnt find one.Going to clean the head and do a proper check then anyone ideas on what's giving way here cheers
Old Nov 20, 2010 | 03:23 PM
What breather you running ?, not ingesting the engine fumes into the inlet like std are you ?
Old Nov 20, 2010 | 04:14 PM
derekd's Avatar
derekd
found out mate was blocked breather hose had frozen was -14 when she tried to start well well time for a rebuild anyways
big_Rad
Sep 15, 2017 09:36 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
mrmann
Aug 20, 2015 11:24 PM
ekjim
Aug 17, 2015 08:57 PM
