4x4 boost fault
Old Nov 18, 2010 | 07:13 PM
r1idiot's Avatar
r1idiot
another money pit!
Default 4x4 boost fault
MY 93 SAFF 4X4 HAS DEVELOPED A FAULT WHEN UNDER BOOST , AS THE BOOST CLIMBS IT SEEMS TO GET SERIOUSLY BOOST NOISY THEN STOPS LIKE A BRICK WALL! AT FIRST I THOUGHT ID BLOWN A HOSE BUT SHE HOLDS A LOWISH BOOST NICELY INLY BRICK WALLING AT HIGHER RPM, SHE WAS RUNNING GREAT UNTIL I CHANGED THE COOLER FOR A 70MM AIRTEC 500 JOBBIE AND LOSING THE DUMP VALVE PREVIOUSLY FITTED TO THE TOP OF THE COOLER, IM MORE OF A FAN OF THE WASTEGATE FLUTTER ANYWAY , THE ONLY OTHER DIFFERENCE IS THAT IVE TAKEN THE VALVE OFF AND CAPPED OFF THE PIPE FROM THE INLET THAT WAS PREVIOUSLY RUNNING THE VALVE , BEFORE DOING THIS THE CAR RAN FINE AND BOOSTED FINE AND IS CURRENTLY RUNNING STAGE 1. ANY HELP OR ADVICE WOULD BE GREATLY APPRECIATED IN THIS MATTER SORRY TO BE A BORING TWAT I JUST WANTED YOU TO KNOW THE DETAILS IN FULL! P.S IDLE IS FINE , LOW BOOST IS FINE AND CAR RUNS WELL OTHER THAN THIS HIGHER END FAULT, THANKS IN ADVANCE PEOPLES
Old Nov 19, 2010 | 08:18 AM
James @ M Developments.'s Avatar
maybe she is now running too much boost and hitting the boost cut?
i would advise a fuelling and boost check.
Old Nov 19, 2010 | 08:28 AM
silky16v's Avatar
silky16v
Get on That!
2 bar map sensor fitted?
most likey hitting boost cut re-fit the amal valve as then ecu has a way of controlling the boost then.
get it setup asap before you break it
Old Nov 19, 2010 | 09:33 PM
r1idiot's Avatar
r1idiot
another money pit!
Thanks for responses here guys found the fault this morning ,pipe had come off amal valve on turbo side , replaced all the crumbly old crap with silicon and shes sweet again thanks guys
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
