C1155 code ABS and traction control lights on
Old Nov 18, 2010 | 05:17 PM
shoestring25's Avatar
shoestring25
Default C1155 code ABS and traction control lights on
hi recently had the traction control light and ABS light come and stay permanently on. garage got the fault code as C1155 which is sensor left front input circuit. could the sensor just need a clean or does the sensor need replacing or is the wire to the sensor damaged? or is maybe the ABS sensor ring damaged?
wee all know what garages are like they keep replacing stuff till it the problem goes away then charge you for all of it even when half of it didn't need doing.
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
