Cam timing
Old Nov 18, 2010 | 12:34 PM
kaisersolsay's Avatar
kaisersolsay
Default Cam timing
Hi,
I have a set of vernier cam pulleys on my cossie and need some advice on how to now time the cams. The verniers don't have any marks therefore can anyone advise on the orientation of the cam lubes when timed up correctly?
Cheers lads!
Old Nov 21, 2010 | 05:32 PM
kaisersolsay
bump
Old Nov 22, 2010 | 02:44 PM
The easiest way to do this, is to set as std timing for now, just put on std pulleys/belt etc and time up as normal, but first loosen a turn of the cam pulley bolt.
Now remove rocker cover and remove the centre cap from each cam, place a bit of leather, old belt etc there to hold cam in position whilst you tighten down the caps again.
Now slacken belt remove std pulleys, put on verniers, this is am much quicker way than dial gauges etc and perfectly fine, then remove caps remove leather etc job done, saves you buying dti gauges etc as well.
You will need to slacken the verniers off so they can rotate as needed to allow the timing belt to tension correctly, don't forget to tighten everything up afterwards.
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
