Info needed - on puma 4x4 wrc
Hi all, I need some help.
Has any one got info on the Puma 4x4 wrc, all info will be gladly apprectiated. Tech info , drawings how many were made etc,etc
Cheers.
Cheers.
official ford numbers or aftermarket makes??
Ford only made a couple of shells, one of which into a full on car which was a demo car before being sold and used in ice racing.
A company called Imtec knocked out quite a few before going under and there are probably 10-20 private built examples out there mostly in a rally or rallycross guise.
Thanks for replying Puma nutter.
Hopefully I will be receiving an ex works shell after xmas, I have seen the shell, not in great detail but via photos and it is the original lhd 4x4 works shell. Never been touched.
So I am trying to get all the info I can to build it as best as I can. This project if it goes ahead will take me a while to complete.
Cheers.
Cheers.
Gordon Vincent built the official Boreham backed cars and made them to accept either Escort Grp A equipment or Escort WRC running gear. Marcus Dodd ran the only Boreham backed car ASAIK
Kevin Proctor definately has one of the boreham spec cars based on a 1998 esc wrc and there is a sister to that although i'm not sure of the equipment level, used in rallycross, the imtec ones never seemed as well specced, pal of mine had one with a quaife seq dog box and a mediocre engine....last time I saw that it was going to Jersey...
John from Ears Motorsport was also building one, not sure if he ever got it finished..
Thanks for the info Ian,
I am not a hundred percent sure it's a ex works shell, but the shell has got the tunnel the rear quaters have been done to take drive shafts fully welded in cage, like I said the car is just a bare shell with doors, boot, bonnet thats it. Never been touched after been fabricated.
Cheers.
Cheers.
. Hello to all there was only 2 Ford Puma WRC 4x4 created by Ford Motorsport. A which(who) was burned further to an accident and the other one is between(in) my hands which(who) was to create in 1998 which then left for on ice running(race) is at present it is classified classic car .Amicalement I am French
Hello, there was only two Ford puma 4x4, created by I have no particular plan but I have the licenses(Bachelor's degrees) of manufacturing. On my vehicle the registration number is R20 FMS. Other vehicle was destroyed further to an accident in rally .Si you have an e-mail I can send you photos of what I have. Friendly yvanmaug@gmail com
jessie_rs
11
Jun 3, 2019 04:57 PM
