I changed the engine but she wont start when hot
Old Nov 17, 2010 | 10:57 AM
William R's Avatar
William R
Default I changed the engine but she wont start when hot
Hi anyone and everyone, I thought I'd try dipping into the fountain of knowledge before I pull the last of my hair out!!
My 1999 1.8 TDI has been a very reliable workhorse over the years, right up to the point where it cut-out dead on a large rural hill. The fuel pump had dramatically given up the ghost. The car had done 160K and was getting a bit tatty but the engine was a good-un with a new turbo only just fitted. So I bought a much tidier car that had an engine knock, with the idea to transplant my engine.
The 'new' car still started on the button and drove well so I ran it for a few weeks until the noise reached a worrying level. Then the transplant was made. My trusty old engine went into the new car, which retained its diesel pump, starter, thermostat and gearbox. We renewed the front wishbones, discs, pads amd rear cylinders. Filled engine and gearbox with top quality oils and replaced air and oil filter. Then we tried to start it.
It turned over well but wouldn't start until we cracked open each of the injector hoses to bleed the air out. Then she fired up lovely. I took her for a spin and she drove spot on. All was well with the world until I switched her off for 20 mins and tried to start again. She kept turning over whilst belching white smoke (fuel?) without a hint of firing. We made good use of the slope outside and bump started her first time. And thus the pattern was set!
For the past two weeks she has started first time, everytime when really cold. She runs like an express train when started but if I try to start her when warm, I only have a 25% chance of success. She bump starts straight away though??
Can anyone shed some light on where I have gone wrong with this as I can't afford to lose much more hair??????
Old Nov 17, 2010 | 12:37 PM
stevo123's Avatar
stevo123
Because the only thing that is different between bumping and using starter motor, that I can see, is is the speed the engine gets turned I would expect a lazy starter. It may not be spinning the motor quick enough for it to catch on. Just a guess but it does make sense. Alternatively it might be a possible ign swith fault in that it may be intermitantly cutting off the *"ignition" as the starter motor spins.
*by ignition I mean what ever device stops the diesel reaching to the engine/pump/injectors - sorry my knowlede is lacking with modern diesels.
Old Nov 17, 2010 | 01:07 PM
William R's Avatar
William R
Thanks Stevo,
I've ruled out the starter motor for two reasons. Firstly it always works from cold and secondly it was working fine right up to the engine switchover. No noticeable change in cranking speed/sound.
I had my battery tested and it was found to be bad. Thinking I had hit the jackpot, I exchanged it for a brand new one under warranty and fitted it with great expectation. The result = No difference!
We've also tried both crankshaft sensors (from both cars) and it doesn't make any difference.
We even changed that complete section of wiring loom for the one on the other car and yes, IT MADE NO DIFFERENCE!!
JoeyBoyden
Jan 4, 2024 02:36 PM
ekjim
Aug 17, 2015 08:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
