OIL LEAK
Nov 15, 2010 | 01:37 PM
OIL LEAK
hi can anyone help? got an oil leak quite badly but its mostly when driving? any ideas
Nov 15, 2010 | 05:34 PM
Is it from the rear wheel ?
Nov 16, 2010 | 07:20 AM
Have you looked to see where it could be coming from? Common suspects are cam seals and the cam cover.
Martin
Nov 16, 2010 | 09:35 PM
Mine had a quite bad oil leak, turned out the rubber hose connecting the oil return from the turbo to sump had split, but it was pissing out.
Nov 17, 2010 | 06:35 AM
No point trying to help as some won't even help themselves!!
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
