Oil pressure gauge....
Old Jan 27, 2005 | 09:06 PM
Filthy Rich's Avatar
Filthy Rich
Default Oil pressure gauge....
Wheres the best place to mount a sender unit to work an oil pressure gauge on a cosworth ??
ta
Rich
Old Jan 27, 2005 | 09:32 PM
CosKev3's Avatar
CosKev3
Where the standard oil pressure switch goes into block m8
You need a switch that will run a gauge and your warning light if u still want light to work
Old Jan 28, 2005 | 04:12 PM
Moonie's Avatar
Moonie
Look on burton power, you can get an adapter which screws in where you oil pressure switch goes, the adapter then has two outlets, one for the switch and one for your gauge.
Old Jan 28, 2005 | 08:43 PM
Filthy Rich
cheeRS lads
must have been having a blonde moment
Will sort a 't' piece out from a hydraulic place tomorrow if i get time
Old Jan 29, 2005 | 06:32 AM
leesrs240's Avatar
leesrs240
Blonde moment
must still be using that hair gel then
Old Jan 29, 2005 | 07:26 AM
Filthy Rich
Well you left it lying around Lee
Old Jan 29, 2005 | 09:12 AM
HYBRiD_T's Avatar
HYBRiD_T
Just get the adapter from Ford for an Escort cossie, straight fit.
Old Jan 29, 2005 | 01:54 PM
leesrs240's Avatar
leesrs240
pmsl at rich i only use it cause it hides the grey..
SMILER258
Sep 28, 2015 09:04 AM
