mot questions and answers
Nov 10, 2010 | 07:30 PM
hi all. i thought i would open a thread to help out with any mot related issues. i am a qualified mot tester for class 4,5 and 7 vehicles.
Nov 14, 2010 | 08:08 PM
Nov 15, 2010 | 08:10 AM
would a zetec on carbs and a CAT pass MOT?? on emissions etc? any experience with this. From a 2002 focus by the way lol
Nov 15, 2010 | 10:11 AM
If the headlight aim was correct etc, is it possible to pass an MOT with an aftermarket HID kit fitted?
Nov 15, 2010 | 02:35 PM
why do you testers always find a reason to fail my cars
Nov 18, 2010 | 06:26 PM
Quote:
Originally Posted by
mobb-black
hi there. impossible one to answer untill its hooked up to the gas analyser to see what the reading is.from the sounds of it i wouldnt have thought the emissions would be acceptable to pass, though you may be able to find a friendly tester!
Nov 18, 2010 | 06:28 PM
alistairolsen
if there is a correct beam pattern and the aim is ok then it will pass yes
Nov 18, 2010 | 06:29 PM
cossiejay
if you own a ford then that fact answers your own question lol
Nov 18, 2010 | 06:43 PM
is it right that reverse lights not workin is just an advisory?
Nov 18, 2010 | 06:44 PM
My fiesta (1979) has started using quite a bit of oil (5ltr's per week) will this show up on the gas analyser or is my car exempt because of its age for the gas test?
If front fog lights are fitted but not working/wired up, is this a fail
Nov 18, 2010 | 06:45 PM
yea turbocab mine didnt work for abit passed mot just advisory got it sorted now switch on gearbox
Nov 18, 2010 | 06:50 PM
if the sides of the seatbelt at starting to fray alittle is this a fail?
i will post pics at the weekend
Nov 18, 2010 | 07:10 PM
mar k run a lighter down it no more frayed edges
Nov 18, 2010 | 07:50 PM
cabriolet
I've seen Mark with a lighter, he will have no more frayed edge because he will have no more seatbelt, or probably even a car
Nov 18, 2010 | 07:57 PM
Can the brake tester be used as a rolling road?
Nov 19, 2010 | 01:19 AM
chaffe
no!
mar_k
need pics tbh
Nov 19, 2010 | 01:20 AM
turbocabessex
not even part of the test mate
Nov 19, 2010 | 01:21 AM
gcfcos
i think you will find it needs self levelling system and headlamp washers to be a pass mate check the book!
Nov 19, 2010 | 01:24 AM
TheScrapman
best way to test it is park in a confined unventilated area, attach a hosepipe from the exhaust and plum it in through the window.
sit in the drivers seat and hold rpm at approx 3000rpm until you die you fucking useless forum troll
piss off you knacker
check his other posts guys he is a nob!
Nov 19, 2010 | 06:30 PM
turbocabessex
hi reverse lights are not part of the test so shouldnt even end up on the advisory sheet
Nov 19, 2010 | 06:32 PM
TheScrapman
on that year it will be just a visual smoke test
Nov 19, 2010 | 06:33 PM
vinnyvangough
front fog lights arent part of the test. the only fog light that needs to be fitted and working is the offside rear
Nov 19, 2010 | 06:34 PM
mar_k
just lightly burn them off with a lighter etc
Nov 19, 2010 | 06:35 PM
chaffe
no way would leave a very expensive mess lol!
Nov 19, 2010 | 06:38 PM
gcfcos
center to o,s,r
Nov 19, 2010 | 06:39 PM
botters
yes your right my apolagies to the chap who asked the question!
Nov 19, 2010 | 06:40 PM
clarke5700
center to o,s,r
correct
Nov 19, 2010 | 06:45 PM
there is a hell of alot of testers on this sight including me lol.
Nov 19, 2010 | 07:58 PM
clarke5700
fair enough probably silly of me to put up a help thread for cars when everyone on here must work on them lol!
Nov 19, 2010 | 07:59 PM
ill leave the thread open for anyone to give advice as didnt realise so many testers on here. only fair
Nov 19, 2010 | 10:54 PM
gcfcos
thanks,
great thread by the way.
maybe there should be a dedicated room set up for testers to answer qs
Nov 21, 2010 | 07:30 PM
can anyone tell me if this would cause the car to fail?
the shocks still work as they should and they dont leak
Nov 21, 2010 | 07:36 PM
mar_k
i would def fail it for the quality of those pics
Nov 21, 2010 | 07:40 PM
chaffe
lol, they were taken on my work phone.
Nov 21, 2010 | 07:51 PM
im going to be running dunlop rally gravels, will these pas an MOT?
Nov 21, 2010 | 07:55 PM
Would you pass my Mk1 Cortina Cossie project? It has a Mk1 Cortina shell but 4x4 Sierra floorpan.
Nov 21, 2010 | 09:31 PM
sirbuynsellalot
depends whats marked on the tyre,
some rally tyres are road legal but not all
Nov 21, 2010 | 09:33 PM
kaisersolsay
as long as its done correctly then no reason why it should fail,
only questions that might need answered is vin numbers wont match,
so prob require a sva?(not sure on the rules for that)
i'm qualified for testing class 1,2,3,4 and 7 so might be able to help out with any bike questions as well(class 1&2)
