ecu help
Old Nov 9, 2010 | 09:32 PM
mikeyb_699's Avatar
mikeyb_699
Default ecu help
Hi guys
Can any one help with this iv got a l6 ecu and have just installed a lambda sensor can I connect the single out to pin 2 to create a closed loop circuit
Thanks mike
Old Nov 10, 2010 | 05:40 PM
oldford's Avatar
oldford
No. Software inside the L6 does not recognize the lambda signal and is not capable of maintaining a closed loop situation. That is if the hardware is present to measure the lambda signal, which I doubt.
For closed loop you need a L8 or P8.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
