Need help
Old Jan 27, 2005 | 03:29 PM
T28 RST's Avatar
T28 RST
Ok then
Default Need help
Just been out in the car, took it out of the garage and put petrol in it, drove to the end of the street and it went onto 3 cylinders then backfired and cut out, tried to start it and it turned over then backfired, now its just turning over and not even trying to start.
Its been in the garage since september, could it be dampness??
Old Jan 27, 2005 | 03:34 PM
If dampness gets into the dizzie it could cause this... Take the cap off and check it..
xr4x4rs's Avatar
xr4x4rs
could be dampness mate
just check the usual
coil
spark
fuel
your metering unit could of stuck or gone down due to being stud
check you dizzy for dampness aswell
hope this helps
Old Jan 27, 2005 | 03:36 PM
T28 RST's Avatar
T28 RST
Ok then
Would it be worth while replacing these just to be sure.
Old Jan 27, 2005 | 03:40 PM
I would just try the obvaous things first that ain't gonna cost u no money.. Then if no luck, then i would try..
Old Jan 27, 2005 | 04:27 PM
Stoo's Avatar
Stoo
Defo sounds like an ignition problem due to it backfiring.
Plugs
Leads
Dizzy&Cap
Rotor arm
Strange how its just happened though when it was running fine before.Suppose it could be dampness..?
But i dont know how to dry it out if you know what i mean
Old Jan 27, 2005 | 04:28 PM
Stoo's Avatar
Stoo
Also what XR4 said,the flap on the metering unit might be a bit sticky so mabey check that too
Old Jan 27, 2005 | 04:35 PM
T28 RST's Avatar
T28 RST
Ok then
Just been out and took the cap off, it soaking with dampness, the cap and rotor arm are very damp.
Will replace them tomorow and hope for the best.
Old Jan 27, 2005 | 04:36 PM
Should be fine once u dry them out...
Old Jan 27, 2005 | 04:50 PM
Stoo's Avatar
Stoo
Well,problem found and soon to be solved.Glad it wasnt anything serious Dave
Old Jan 29, 2005 | 04:03 PM
T28 RST's Avatar
T28 RST
Ok then
Been out and fitted the new distributer cap and rotor arm and its running perfect now
Old Jan 29, 2005 | 04:10 PM
david's Avatar
david
Glad it was summit simple Dave
