Fan/Aircon
Old Nov 6, 2010 | 08:40 AM
krill's Avatar
krill
Default Fan/Aircon
Hi, just bought an ST with Aircon and the problem is - light on Aircon button lights, fan doesn't work on 1,2,3 or 4, fan works on setting 5 but Aircon light goes out, any ideas please???
Old Nov 6, 2010 | 09:42 AM
Fan resistor is duff, VERY common on lots of fords, maybe also your air con is empty.
Old Nov 6, 2010 | 12:24 PM
martysmartie's Avatar
martysmartie
What he ^^ said, the air con contains a pressure switch if it needs regassing there won't be sufficent pressure and hence no air con.
Martin
Old Nov 6, 2010 | 03:09 PM
krill's Avatar
krill
Thanks for the reply Tabetha, where do I find the resistor ??
Chris
Old Nov 6, 2010 | 05:42 PM
martysmartie
It's behind the dash passenger side, it's like an electronic module hence the name 'Resistor Pack' (Need to drop glove box)
Martin
Old Nov 6, 2010 | 06:32 PM
cabriolet's Avatar
cabriolet
see post 7 down from this one discussed in detail
Old Nov 7, 2010 | 09:31 PM
krill's Avatar
krill
Thanks for the help, found it and ordered one
