ST Gearchange
Old Nov 6, 2010 | 08:32 AM
krill's Avatar
krill
Default ST Gearchange
Hi, just changed from tdci to ST 170 which I love but the gear change is quite stiff compared to the tdci, is this normal or is there a fix please?
Old Dec 9, 2010 | 02:15 AM
pdfbt40's Avatar
pdfbt40
I'd say normal, but obviously worth checking for burnt cables etc. Stiffness can be checked by disconnecting the gearbox ball joints.
Some people remove the counter weight to reduce inertia in the mechanism. Personally I didn't think it improved the feel at all. I reduced the pre-load on the shift detent by modifying an early IB5 one to fit. That reduces the holding force on the system at back/centre/forward which makes it easier to move.
bloopeta
Sep 10, 2008 06:57 PM
Matt_fez
Jan 16, 2006 02:23 AM
aldy
Dec 5, 2005 06:32 PM
Jim Galbally
May 8, 2005 10:47 AM
