s1 rst cold idle problems
Old Nov 3, 2010 | 12:07 PM
ashboirst's Avatar
ashboirst
Default s1 rst cold idle problems
thinking about buying a s1 rst, its been rebuilt with a 1900 arp bottom end, been converted to run efi, it needs a little help to idle from cold, need to keep foot slittly on accelerator but when the car is warm it runs as it should and idles no problem any ideas on what this could be and how to fix it and most important how much it gona cost me lol, any help would be good cheers
Old Nov 3, 2010 | 07:05 PM
I'd get a fuelling check done first, if it's running slightly lean then tweaking the mix will sort this issue and the cold idle.
Don't know what ecu you have but hopefully it's adjustable cheaply.
Old Nov 3, 2010 | 10:58 PM
ashboirst's Avatar
ashboirst
ok cheers mate anyone know where the best place to take this to get it checked in the south east, kent, essex
Old Nov 4, 2010 | 07:51 AM
I don't know your area well, but even a MOT garage can check the CO, but for safetys sake I'd get a full rolling road fuelling check done, can save a melted engine if mixture very out.
The nearest I can think of to you is TOTD, that I'd trust, torque of the devil, ask for chris.
Billy_RS
Sep 13, 2015 04:17 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
