RS Turbo Oil Pressure Gauge Fitment
Hi guys,
got fitting kit etc just wondering where I put it on block etc? Do I replace original pressure switch or leave it in? anyone who has one and can post some pics would be awesome
these better? I have other option and fitted on to end of connection straight on block then attached oil feed to turbo onto it? wrong place? Dunno if it where I fitting or if ive maybe got dodgy connections somehwere
Just use a block fitting that takes both the oil pressure switch and the temp sender, about £6 or so from the bay, if the block also feeds the turbo from the end of the fitting with it being a hex bar, on some there is enough depth to drill and tap for the extra temp sender.
Or you could drill and tap the sump plug and put there, if it's a 1/8NPT temp sender like most are, I can do this FOC for you, just pm me.
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mrmann
Aug 20, 2015 11:24 PM
