diffrent options for clocks in a series 2 dash ???
formerly beefy-rst-2
as title folks,
putting a modded s2 dash in the s1 cossie - i hate s1 dash's
so with it running a s2 car loom and aftermarket management ,
im wondering what options i have for clocks ,
not nessacarily a stack dash or cossie clocks , thinking more a set of stock clocks from another model or make ????
anyone got any ideas , thoughs , would liek something diffrent ,
pref that can be made to work re speedo and revs , mech drive ,
inputs ???
dont mind a bit of modding lol
inputs ???
considerd the gte dash , but they go for silly pennies nowadays dnt they ?
mojo , that looks well , like a budget stack setup rainbum sells,
thats my best option id already come up with ,
just wondering if theres out there from a modern ford that may fit ,
or another car ,,,,,,,
They do small water temp and fuel guages too but they will have to wait till I have more cash! lol
What are these like to fit ? much work involved to get them working ? want to do a similar thing with mine
Sod your ideas of looking modern, it's an 80s car... go the whole hog!
http://www.youtube.com/watch?v=F5zs6TU32pY
I will be eventually using a 7" tft screen to display tuinerstudio via a modded netbook, it will power up when the 12v supply is activated and switch off when removed. The dash display is able to be fully customised to whatever display you want, I like this as my engine will only be low reving so a 9k reving disply would be pointless for my application. At the mo this can only be done with MS or Mtech as far as i know.
7" tft touch screen - £130.00
Netbook - £199.99
PC Technician to modify netbook to self boot when power supply is received £50 - 100
The rest is all sensors, you would need a driver i think for afr but prety much everything else is straight forward.
p.s. mapping is made much easier as the laptop is always connected. There is still a bit more research into the actual performance of this but im gonna give it a try once the cars is up and running
Netbook - £199.99
Very interesting thread, I`m considering changing my clocks, and want some decent clocks, but at a reasonable price.
Have seen stack ST200 tacho and electric Speedometer but prices are very high!
Also can anybody show the fitting and connections for the electric speedo? Can the original ford electric sender in the BC gearbox be used?
Matt at mtech as well
You wouldn know if and how i could go about it would you, i mean does the setup run off cable or the box pickup and would it just plug in and go.
thanks adam
The gauge is made by cai if you google cai gauge u will find them they make smiths and revotech gauges the gauge is electronic it's basically a case of wiring it tl your speed sensor on the st170 box and calibrating it it's really easy hope this helps
yeah seems it mate ,
tbh im a bit of a gauge fan ,
i like the idea of a quick glance and being able to see what a gauge is reading ,
but something like that for revs and speed would work well ,
This is what mine will look like when I get the Fuel and Water temp gauges too....
Obviously ignore the extra bottom two gauges, but that is pretty close to how it will look in my dash, I prefer the two larger gauges central and the smaller ones either side over how the standard RST ones are.
lolIt's a shame I cant do it all in one hit really, but the fuel and water temp gauges are on my Christmas list
Kiran1600E
11
Oct 2, 2015 11:35 AM
