Oil Return Leaking
Old Nov 1, 2010 | 10:43 AM
Rogeyboy's Avatar
Rogeyboy
Default Oil Return Leaking
My oil return on my T3 is leaking, where it connects to the bottom of the turbo core, ive tried taking it off and putting a new gasket and new return metal pipe on but it still leaks.
Its coming from around the gasket - any ideas on a cure anybody?
Many thanks
Roger
Old Nov 1, 2010 | 10:09 PM
kermitt's Avatar
kermitt
Tighten it with a long extension bar and socket.
Old Nov 1, 2010 | 10:16 PM
Rogeyboy's Avatar
Rogeyboy
How tight, i dnt wanna snap it as its already well tight!
Do they commonly leak?
Old Nov 1, 2010 | 10:27 PM
studabear's Avatar
studabear
get hold of a new oil return pipe, or have it skimmed at a machine shop incase its slightly warped
Old Nov 2, 2010 | 10:56 AM
Rogeyboy's Avatar
Rogeyboy
Good call... I'l give that a go with my spare pipe!
Old Nov 2, 2010 | 11:06 AM
chaffe's Avatar
chaffe
Turbocharging Technician
As above, could be warped, they can be quite fussy to seal, also make sure the face on the turbo is clean and free from old bits of gasket
Old Nov 2, 2010 | 12:44 PM
Rogeyboy's Avatar
Rogeyboy
Brilliant, cheers for the help guys!
I'll bring my spare pipe into work tomorrow and skim it, the turbo face is nice n clean - nothing on it at all... Im wondering to run the engine once its on and when shes nice n hot nip it up tighter!
Old Nov 14, 2010 | 06:52 PM
Rogeyboy's Avatar
Rogeyboy
Skimmed flange, brand new "cometic" gasket all done up mega tight and the little s**t still leaks...
Any further ideas please...?
Also how is an oil return fitted to a Fiesta RST block running a T3?
Old Nov 14, 2010 | 06:56 PM
Red_bull's Avatar
Red_bull
I have the same problem! Also tried a second pipe, but no luck. I think my turbo is a bit wraped on that place. Strange do... :S
Old Nov 14, 2010 | 07:02 PM
chaffe's Avatar
chaffe
sounds strange, did you put a wipe of silicone both sides of the gasket, i normaly do
Old Nov 14, 2010 | 07:10 PM
studabear's Avatar
studabear
try using 2 gaskets
Old Nov 14, 2010 | 07:28 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
are you sure its not leaking from the feed at the top of the turbo and working its way round?
when fitting a t3 on a frst engine you use the the s2 oil feed it will fit direct on the back of the frst T pice but as for the drain you can remove the threeded drain pipe and fit a s2 stub type drain.
Old Nov 14, 2010 | 07:43 PM
craig rst kid's Avatar
craig rst kid
vw do a gasket sealant that should do the job
Old Nov 14, 2010 | 09:45 PM
Rogeyboy's Avatar
Rogeyboy
The cometic gasket i used is alot thicker than a normal ford item and i wouldve expected that to seal. Ive tried hymolar gasket sealant on both sides of the gasket with no luck. It def coming from the return.
Where could i find and Escort RST stub/push fit style return that goes in the block? Im using a fiesta Block and threaded return, altho that end is not leaking!
Old Nov 15, 2010 | 07:22 AM
chaffe's Avatar
chaffe
the weld on the return pipe isnt cracked is it? or the bottom of the cartridge isnt cracked?
Old Nov 15, 2010 | 10:07 AM
Rogeyboy's Avatar
Rogeyboy
Worth a check of the turbo core i guess... It cleaned up nicely tho, with no obvious damage to it. And the weld is fine on both pipes...
I might cut the metal pipe back and use a longer peice of rubber as the return elbow, as i think its stressing the flange?
Old Nov 15, 2010 | 05:57 PM
gup's Avatar
gup
ive seen before that the tubo core is leaking and everyone thinks its the oil feed drain
check aroung the turbo unit itself and have you checked that all your breathers are clean and clear so the oils not backing up a tad
Old Nov 21, 2010 | 07:41 AM
Rogeyboy's Avatar
Rogeyboy
Problem found....!
The core/exhaust housing is leaking oil, Its coming from where the 2 join, ive tightened the bolts that hold the exhaust housing on and its slowed it right down to a weep.
Now obviously i shouldnt be getting oil in the exhaust housing...!
New turbo time?
Old Nov 21, 2010 | 09:41 AM
studabear's Avatar
studabear
rebuild or repair
Old Nov 21, 2010 | 04:30 PM
Rogeyboy's Avatar
Rogeyboy
Yeh thought as much...
Bloody hell! Rads weeping abit aswell, might aswell replace that at the same time lol!
All expense before xmas eh!?
Old Nov 21, 2010 | 04:35 PM
mattseries2's Avatar
mattseries2
Get used to it! Its a ford
Old Nov 22, 2010 | 11:33 AM
Rogeyboy's Avatar
Rogeyboy
R U hinting towards "Fixed Or Repaired Daily" lol?
Bloody cars eh!?
Old Nov 22, 2010 | 11:37 AM
chaffe's Avatar
chaffe
Bloody cars eh!?
better that "lots of trouble, usualy serious" or "fix it again tommorow"
timsrs
Nov 13, 2018 11:48 AM
155lee
Oct 27, 2015 04:55 AM
timsrs
22
Sep 24, 2015 08:14 PM
krypton
Sep 23, 2015 07:29 PM
talon1
Sep 15, 2015 10:27 AM
