Black Smoke
Old Jan 26, 2005 | 11:12 PM
Skiman's Avatar
Skiman
Default Black Smoke
Ive got a tiny tiny bit of black smoke once you lift off after revving the car, i dunno if it happens while the car is driving as i cant see anything, but if you are stationary and rev it a bit then let off, a tiny bit, now not a lot, jus a bit of black smoke comes out, what does this mean?
T25 Escort Cossie btw
Ta
Old Jan 26, 2005 | 11:32 PM
bud-weis's Avatar
bud-weis
Football Cwazy
black smoke is usually overfuelling i think mate.
Old Jan 26, 2005 | 11:37 PM
Skiman's Avatar
Skiman
Overfuelling ? Could this be the cause of the backfiring im getting on full boost? i thought the fueling was run by the ECU, so there is no way of turning it down?
Old Jan 26, 2005 | 11:44 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yeah that could be your problem. if i was you i'd book it in for a tune up at a well known and reputable rolling road. will probably be like a different car when it's done. definitely sounds like fuelling probs though.
Old Jan 27, 2005 | 12:05 AM
Skiman's Avatar
Skiman
thing is, all the rolling road people here in n.ireland only do jap cars and dont know the first thing about fords....what to do....
Old Jan 27, 2005 | 01:07 AM
bud-weis's Avatar
bud-weis
Football Cwazy
oh didn't realise you were in northern ireland. could you get a boat across and then go to motorsport developments in blackpool.or you could just take it in to somewhere in N.I. and ask them to check the base C.O. levels at idle. then they can adjust if necessary i suppose.
Old Jan 27, 2005 | 01:22 AM
Skiman's Avatar
Skiman
Well it passed the mot yesterday does that mean its ok?
Old Jan 27, 2005 | 08:14 AM
bud-weis's Avatar
bud-weis
Football Cwazy
yeah to be honest it should be ok to pass an m.o.t . i would honestly get it over here mate and have it looked at by an expert. fuelling trouble is usually the main reason a turbo car will die. it may be running all over the shop and you don't wan't problems with it leaning off or even being too rich and causing borewash. is it modified?
Old Jan 27, 2005 | 12:26 PM
Skiman's Avatar
Skiman
Yup just did it a few weeks ago...
K&n conefilter
stage 2 ggr 305 bhp chip
-31 actuator
full mongooose exhaust system
and an uprated fuel pump which arrives 2moro....
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
