Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
fitting 2ltr zetec in my fiesta
Old Oct 29, 2010 | 11:41 AM
mudmenace's Avatar
mudmenace
Default fitting 2ltr zetec in my fiesta
hi all im new to this forum iv being modifying 4x4s for offroad most of my life now fancy something faster as my insurance has gone down now im 25 and got a mint 1.1 fiesta 3rd and want some advice on fitting a 2.0 zetec lump and how to go about it like engine mounts wiring and parts i need lay my hands
Old Oct 29, 2010 | 05:38 PM
xrmalin's Avatar
xrmalin
what mark fiesta is it ?
Old Oct 29, 2010 | 07:15 PM
mudmenace's Avatar
mudmenace
its a mk3 fiesta classic 1.1 on a N plate
Old Oct 30, 2010 | 06:16 PM
xrmalin's Avatar
xrmalin
Id say your best bet is to have a look for a fiesta si thats failed its mot and is going cheep as that will have pretty much everything you need as they had a zetec engine in as standard so you'd have the engine mount,wireing loom and sump/oil pick up you need to put on the 2.0l to get it working as it should plus all the little clips,screws and brackets you always forget you need. You would steel need all the injectors and ecu from the 2.0l aswell as it wont run properly on the 1.6 stuff.
Old Oct 31, 2010 | 12:48 PM
mudmenace's Avatar
mudmenace
ok thanks for that yer ill have a look out for a cheap si i want to keep my shell as its completly mint only done 53,000 from new with 2 owners thanks again
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
Aug 10, 2015 12:08 PM
turbobill
Aug 1, 2015 08:55 PM
