Turbo refurb?
Old Oct 27, 2010 | 07:45 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Default Turbo refurb?
Best place to get my turbo refurb ? Cheers
Old Oct 27, 2010 | 07:48 PM
mk2rstaff's Avatar
mk2rstaff
back of fast ford or ebay mate loads of companies
Old Oct 27, 2010 | 07:53 PM
orionmojo's Avatar
orionmojo
Pm Christian. he knows a place, excellent prices too.
Old Oct 27, 2010 | 07:54 PM
essexRSTSouthend
Thanks
Old Oct 28, 2010 | 01:48 PM
essexRSTSouthend
Reason im thinking of a refurb,due to tiny play back and forth play.works fine etc,done over 100k on turbo,so it had a good life.how much play is too much? Probably been asked on here loads,so sorry in advance.
Old Oct 28, 2010 | 07:34 PM
mk2rstaff's Avatar
mk2rstaff
a small bit front and back is ok mate, its up and down or side to side thats bad, if its not smoking or burning oil then it should be fine, but if your set on it to be safe then its worth doing IMO
Old Oct 28, 2010 | 07:44 PM
mr_joe0606's Avatar
mr_joe0606
its pritty normal to have a bit off side to side play under 1 mm. in and out is the bad one.
companys cr turbos are pritty good
Old Oct 28, 2010 | 08:14 PM
kermitt's Avatar
kermitt
PM Wilky on here, he sorted mine for a good price.
Old Oct 28, 2010 | 09:23 PM
stickertone's Avatar
stickertone
speak to vince at cr turbo's. what he doesnt know aint worth knowing... cheers
Old Oct 28, 2010 | 10:01 PM
mk2rstaff's Avatar
mk2rstaff
sorry wrong way round mate
Old Oct 28, 2010 | 10:08 PM
essexRSTSouthend
Lol thanks guys.yay got very small movement in and out.car been sitting for month,thought id check it.turbo fine but that in and out got me wondering.
Old Oct 28, 2010 | 10:10 PM
mk2rstaff's Avatar
mk2rstaff
before you start the car again a good idea to take off the dizzy cap and turn engine over for 30 secs to get some oil around the turbo before full start up mate its called priming the turbo, saves running it dry
Old Oct 28, 2010 | 10:31 PM
essexRSTSouthend
Old or new turbo?
Old Oct 28, 2010 | 10:42 PM
mk2rstaff's Avatar
mk2rstaff
for both mate as they will dry out if left stod still, its precausionery really, tick over is about 750 rpm with a tendancy for your turbo to spin up fast on start up and most probably be very dry of oil unless you use some sort of fully synthetic or wynns coating, so best to be safe and just prime it mate
Old Oct 28, 2010 | 11:16 PM
essexRSTSouthend
So with the car sitting about with no oil in the turbo could cause the play.once oil in the turbo it should'nt move in and out.. sorry if im having a blonde moment.
Old Oct 28, 2010 | 11:33 PM
mk2rstaff's Avatar
mk2rstaff
no wear will only be caused by it being dry on start up or old age after abuse which its does not seem you have, if you are going to start it after a long period of non use its best to prime to be safe and put oil in first before you start the car
Old Oct 28, 2010 | 11:43 PM
essexRSTSouthend
chhers mate
Old Oct 28, 2010 | 11:48 PM
Chopshop85's Avatar
Chopshop85
I used these guys when I rebuilt my engine.
http://www.turbodevelopments.co.uk/
Not a bad price.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
