Removing front hub/wheel bearing?
Old Oct 24, 2010 | 07:02 PM
mattseries2's Avatar
mattseries2
Default Removing front hub/wheel bearing?
Im doing a wheel stud conversion and need to know how i get the hab part that the wheel bolts screw into? Mite aswell fit a new wheel bearing while im at it so how do i remove bearing and centre part of hub?
Old Oct 24, 2010 | 07:43 PM
studabear's Avatar
studabear
remove brake caliper and carrier, disconnect track rod end, bottom ball joint, driveshaft nut, slide cv joint out of hub. undo shocker to hub bolt and knock the bearing housing off the shocker, you can then seperate the hub and bearings etc
Old Oct 24, 2010 | 09:04 PM
mattseries2
The hub is already off, just need to know how i get off the part of the hub that the wheel/disk bolts to as it dosnt seem to want to come out. Dont know if it needs to be pressed out etc?
Old Oct 24, 2010 | 09:33 PM
little bram's Avatar
little bram
yes mate will have to be pressed out
original
Apr 28, 2026 05:20 PM
Aug 29, 2015 08:16 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
