Is it a tall block?
Old Oct 24, 2010 | 06:38 PM
grant_xr's Avatar
grant_xr
Default Is it a tall block?
My xrt was smoking heavy when up to running temp and the idle had became erratic. I done a comp check and each cyl was around 130psi but cly 2 was higher (around 150).
Ive stripped it, plan is to fit new rings and get the turbo re-con'd as there is a lot of up/down play and a little in/out. I also checked the valve guides for play and there is a little play there so may get them done for good measure.
Anyway ive always been keen to have a look inside my engine as ive got the receipts from specialised engines who built it. Its meant to be a 1.9 tall block with low comp pistons, arp rod bolts stage 3 big valve head etc.
The pistons have a little JM stamp on them?
Heres some pics of the pistons/block let me know your opinions....
Grant
Old Oct 25, 2010 | 12:41 PM
muz's Avatar
muz
Wye Valley Hardcore
Well the block has 18 cast into it, so it's an 1800 Sierra block, possibly over bored to 1900cc. They are ford rods so guessing the standard 1800 rods, not sure on pistons but aren't 1800 Sierra pistons. Also those aren't ARP bolts. At least, not any ARP bolts I've seen.
Old Oct 25, 2010 | 02:12 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
look like 1800cvh rods.
Old Oct 25, 2010 | 08:37 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Is this one bent at the top?!
Old Oct 25, 2010 | 09:32 PM
BRAM's Avatar
BRAM
Yeah i thought that aswell, it does look like it.
Old Oct 25, 2010 | 10:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Pistons look cast to me too.
Old Oct 26, 2010 | 09:32 AM
grant_xr's Avatar
grant_xr
cheers for the info guys, as for the one that looks bent, i'll have a closer look tonight. Someone on another forum seemed to think the pistons looked to be forged. Any way of knowing for sure?
Grant
Old Oct 26, 2010 | 10:16 AM
Versus_Creations
Ask me a question!
Without them in hand its hard to say, i would also guess cast because of the casting mark just next to the pin on the piston. If it was forged it wouldnt have that marking.
still only guessing tho could be wrong?
Old Oct 26, 2010 | 10:58 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah thats what made me think cast, in addition to that I dont think there a many forged pistons that dont have a fully floating little end.
Old Oct 26, 2010 | 11:12 AM
muz's Avatar
muz
Wye Valley Hardcore
They look pressure cast to me? Anyway, the pistons aren't really the issue, I'd be worried about the 1800 rods and standard bolts if you want to up the power. Pistons should be fine
Old Oct 26, 2010 | 12:12 PM
grant_xr's Avatar
grant_xr
Yeah im gonna have to give that some thought, before it was stripped it had been running 16psi after a custom map by MSD.
Whats the options rod wise? Are the 1.8 rods a different length than 1.6 or is it made up by the throw of the crank?
Grant
Old Oct 26, 2010 | 10:48 PM
JoshXR2's Avatar
JoshXR2
those pistons are from america from the 1900 cvh i have the same in my car they have been machined down for turbo applicatio
Old Oct 26, 2010 | 11:01 PM
Canada1's Avatar
Canada1
The pistons are definitely cast.
The North American pistons would not stand up to much abuse.
They were never designed for turbo applications - unlike the Mahle 1.6 turbo pistons
which are cast as well, but very well engineered.
Old Oct 27, 2010 | 06:07 AM
grant_xr's Avatar
grant_xr
Rod isn't bent, had a look last night. Turns out my bores are scored to fuck tho so prob gonna go zvh now. Will be an overall stonger bottom end than this.
Grant
Old Oct 27, 2010 | 09:43 AM
muz's Avatar
muz
Wye Valley Hardcore
"Specialised" engines strike again
Old Oct 27, 2010 | 03:32 PM
s1cab's Avatar
s1cab
Old Oct 27, 2010 | 04:50 PM
craig rst kid's Avatar
craig rst kid
I am glad I didn't buy a bottom end of them nowas i was going to when my bottom end was fucked
Old Oct 27, 2010 | 06:48 PM
s1cab's Avatar
s1cab
when i first got my series one i blew the bottom end up had one of their ''stage 2 low comp'' bottom ends, new sump and ap 4 paddle clutch guess what they charged me...
Old Oct 27, 2010 | 06:59 PM
studabear's Avatar
studabear
half a curly wurly and a bag of belly button fluff?
Old Oct 27, 2010 | 07:01 PM
Rob_DOHC's Avatar
Rob_DOHC
Mars bar and a blow job i reckon....
Old Oct 27, 2010 | 07:19 PM
s1cab's Avatar
s1cab
£2650 !!!! satndard rods and pistons just machined down...
Old Oct 27, 2010 | 07:23 PM
Rob_DOHC's Avatar
Rob_DOHC
JESUS thats a fair bit
Old Oct 27, 2010 | 07:27 PM
s1cab's Avatar
s1cab
i paid it tho
Old Oct 27, 2010 | 07:30 PM
studabear's Avatar
studabear
Dick turpin wore a mask
Old Oct 27, 2010 | 07:48 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Bloody hell
Old Oct 27, 2010 | 10:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Fuck!!!!
We need a 'Smilie' being fucked up the arse for posts like this! lol
Old Oct 28, 2010 | 05:53 AM
grant_xr's Avatar
grant_xr
Fuck!!!!
That roughly what my engine cost new i think, got the receipt somewhere. I bought it second hand off a guy called steve rs on here for £1000. It had apparently only been run in when i bought it.
Grant
Old Oct 28, 2010 | 07:12 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It's terrible really, those engines are worth sweet FA! Just an NA bottom end with skimmed pistons
Old Oct 28, 2010 | 07:28 AM
rsmark86's Avatar
rsmark86
gutted i paid 1500 for my engine and has only done running in miles and is a proper built cvh..... so always best to shop about....
i was going to just pay a company to do a standard rebuild but for half the price i brought a proper cvh....
to be honest mate if you want a good engine i wouldnt bother with a zvh i would either do a big spec cvh or go full zetec turbo as the zetec is the same price as a zvh and is a much better conversion
Old Oct 28, 2010 | 07:39 AM
Rob_DOHC's Avatar
Rob_DOHC
Think my engine is costing £600-700 to build to a very high standard. lol a higher standard than specialised engines anyway!
Rob,
Old Oct 28, 2010 | 12:00 PM
s1cab's Avatar
s1cab
Fuck!!!!
Old Oct 28, 2010 | 12:03 PM
s1cab's Avatar
s1cab
Rob,
carboard pistons would probly be better than specialised engines shit they fit ! but they get away with it and people still use them ! a mate of mine had a escort gti think he paid 2800 for a stage 3 engine they said it would make at least................. 280bhp
Old Oct 28, 2010 | 05:06 PM
grant_xr's Avatar
grant_xr
I bought that engine a few years ago now, live and learn tho! Yeah ive been having a think and if i do go ahead with another engine think it'll be a full zt. Will be a while tho cause i'll prob go for steel rods and forged pistons!
Grant
Old Oct 28, 2010 | 06:17 PM
rsmark86's Avatar
rsmark86
Grant
it might be worth giving jamsport a ring as they do a good 1900...
but i would do a zetec turbo if i was to build another ...
Old Oct 28, 2010 | 06:43 PM
Keenyzs's Avatar
Keenyzs
I have one of these "stage 3" specialised bottom ends in my s2. My bro paid around £3000 for it and a few other bits. It was also supposed to have arp rod bolts, but doesnt! i am led to believe that these are a 1800 block, rods and crank with machined pistons, the problem is if you read the small print it sayd "based" on an american tall block!! Mine has been rebuilt twice now, first time after about 2k due to piston ring snaping and doubling over another and the second time it melted a piston. I am now saving for a different engine as i know this isnt going last 5 minutes again. Like you say we all live and learn.
Old Oct 28, 2010 | 06:49 PM
rsmark86's Avatar
rsmark86
someone buy that 2.1zvh thats for sale or it might end up at mine as a spare lol
i keep looking at it and thinking mk2 fiesta lol
Old Oct 28, 2010 | 07:11 PM
Canada1's Avatar
Canada1
I can't believe the pricing!
I will attempt to clear up some misconceptions.
The UK 1800 block is not the same as the USA/Canada 1900 block.
The UK 1800 has 80mm bore and 88mm stroke.
The USA/Canada 1900 has 82mm bore and 88mm stroke.
The bore thickness on the standard USA/Canada 1900 is 4.5mm to 6.2mm
Cylinder wall thickness measured with an ultrasonic thickness tester.
Boring a UK 1800 +2.0mm to use standard USA 1900 pistons is a disaster waiting to happen. These blocks are only good for a +1.0 mm overbore - at most.
Hope this helps.
Old Oct 28, 2010 | 08:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not really suprising now we know they are just 1.8 CVH's skimmed for lower comp
Cant beleive they do it and dont expect people to find out?!
Old Oct 28, 2010 | 09:49 PM
Keenyzs's Avatar
Keenyzs
Like i say the advertise it as "based" on the american tall block, thats how they get away with it.
Old Oct 28, 2010 | 10:33 PM
rsmark86's Avatar
rsmark86
i think they need smacking in the face with a con rod the bell ends lol
