4x4 inlet plenum on a 2wd 3dr. What are the benefits?
What are the real benefit of fitting a 4x4 inlet plenum on a 2wd?. Is it worth getting one fitted?
Also is it easy to fit?
you get better intake efficency in the cylinders especially number 1 and 4 and it seems its more than capable of big yb power .
For the cost of big hp and torque engines it seems a no brainer other than the fitting niggles it can produce , not seen mild cossies with one but i reckon it would make better engine correctly mapped too . Tests were done on 3 differing engines , also different dyno,s with the hart and all seemed to gain performance and effeiency.
I have a booklet on the hart plenum showing its results, only saw a slight reduction in an example they gave , think it was a rally engine , slightly less torque iirc low down for a short period , but exellent even cylinder filling resulting in safer afr,s and egt,s per cylinder
edit edit edit----- what a tit lol , got hart in me head from the other thread
sorry guys/girls
woops AGAIN
mike
sorry guys/girls
woops AGAIN
mike
As said flows better than a 2wd and is 1 peice rahter than 2 like a 2wd one.
Been told to change mine over before getting it set up and leaves more scope later on if i decide to run more power!!
dojj
28
Sep 11, 2015 10:00 PM
Adam Graham
Sep 6, 2015 06:04 AM
