gearbox types
i'm not aware of two different S2 gearboxes?
There is a difference between the S1 & S2 box - the S1 box can be fitted to a S2 but a S2 box can not be fitted to a S1 because of the location of the engine mountings.
frst geaboxes dont have a lsd in them, get another s2 box (ive only ever seen 1 type for the s2) easiest way to check its a propper s2 box is to look in the drive shaft hole and u should be able to see straight though, if u can see 2 pins then its a non lsd box
chowfornow
14
Jan 5, 2019 09:01 PM
