Bailey oil breather wrecking my metering unit?
Hey folks just purchased an xr2 turbo which has a bailey oil breather fitted to it and is plumbed into the metering unit! problem isthe spark plugs are covered in shit, the metering unit has oil inside it when i push down the flap and look inside and theres oil coming out the dump valve! any suggestions?
vent it to either a catch tank or atmosphere and block off the metering unit, if money is tight then fit the pipe into a pop bottle or similar to catch the oil just make sure it isnt a tight fit in the bottle as air needs to escape as well
Money aint tight but the engine bay is lol so a catch tank would defo not fit! cheers for the advice mate
Turbocharging Technician
As i said last night mate, we will just vent the bastard to atmosphere, never been a fan of putting the breather back into the inlet.
lol, not good if your ring is worn
the other way of looking at it is the breather aint doing its job correctly of seperating the oil from the fumes, the oil should go back to the block and the fumes back into the metering unit. Ive already blanked off your metering unit with a turned plastic bung mate
the other way of looking at it is the breather aint doing its job correctly of seperating the oil from the fumes, the oil should go back to the block and the fumes back into the metering unit. Ive already blanked off your metering unit with a turned plastic bung mate lol, not good if your ring is worn
the other way of looking at it is the breather aint doing its job correctly of seperating the oil from the fumes, the oil should go back to the block and the fumes back into the metering unit. Ive already blanked off your metering unit with a turned plastic bung mate Thread
155lee
Oct 24, 2015 11:11 AM
Adam Graham
Sep 6, 2015 06:04 AM
lol
