Wheel stud conversion lengths?
Old Oct 21, 2010 | 04:23 PM
mattseries2's Avatar
mattseries2
Default Wheel stud conversion lengths?
All you who had done a stud conversion, what length studs are you using? My Comps have quite a large offset and need longer ones as the std ford bolts were a little too short.
What lengths in mm?
Old Oct 21, 2010 | 05:56 PM
mattseries2
anyone?
Old Oct 21, 2010 | 06:06 PM
Rob_DOHC's Avatar
Rob_DOHC
I will have a measure for you at the weekend if no one else replies mate,
Rob,
Old Oct 21, 2010 | 06:15 PM
mattseries2
Ok Rob ta.
Not sure if 63mm will be too long or next size down is 47mm, will that be too short lol?
Old Oct 21, 2010 | 06:38 PM
Rob_DOHC's Avatar
Rob_DOHC
pretty sure mine are 47mm.... but thats on standard wheels, you could always just get the long ones and grind them down to suit....
Old Oct 21, 2010 | 06:47 PM
rsmark86's Avatar
rsmark86
do you use your standard hubs with the stud conversion or do they need to be changed
Old Oct 21, 2010 | 08:33 PM
Rob_DOHC's Avatar
Rob_DOHC
Yes mate, i have some photos some where....
You have to drill out your hubs and press in new studs, pretty easy, best to get some one else to do it unless you have a pillar drill etc.
Rob,
Old Oct 22, 2010 | 11:47 AM
luke19790_3's Avatar
luke19790_3
i've got some from rally design 63mm i think, but you don't need to mess around with your hubs. because they have a thread on just screws in place of your old wheel bolts.
Old Oct 22, 2010 | 12:08 PM
muz's Avatar
muz
Wye Valley Hardcore
I'm pretty sure mine are 47mm with ET35 Comps and they are fine.
Old Oct 22, 2010 | 04:28 PM
mattseries2
Are they quite a wide offset muz? As my standard wheel bolts where quite short with mine so need extra length on the studs.
jessie_rs
62
Aug 6, 2019 09:27 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
povey@pembrokeshire
Wheels and Tyres
Sep 9, 2015 06:44 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
