escort rs turbo s2?
Old Oct 20, 2010 | 07:31 PM
martin27's Avatar
martin27
Default escort rs turbo s2?
i have been told that my turbo is a garreta,is this turbo a standard(s2),can they handle a boost valve cos im gona put 1 on,do u no which is the best 1 to go for,or is there a point to getting 1
Old Oct 20, 2010 | 07:35 PM
mr_joe0606's Avatar
mr_joe0606
to be honest mate i would not just turn up to boost unless its being setup.
Old Oct 20, 2010 | 07:43 PM
martin27's Avatar
martin27
is that the standerd turbo m8
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
garrat t3 as standard, will be able to handle a boost valve, 1 bar is normally gd but as joe said without a setup may not help......more boost = more problems
Old Oct 20, 2010 | 07:46 PM
martin27's Avatar
martin27
do use have a boost vaule
Old Oct 20, 2010 | 07:48 PM
martin27's Avatar
martin27
dont no alot about turbos am just geting in 2 them thanks for ur help lads
Old Oct 20, 2010 | 07:50 PM
gingerturbo
i dont really rate them as there too easy and tempting for people to piss about with amal valve is just as good when setup
Old Oct 20, 2010 | 07:51 PM
mr_joe0606's Avatar
mr_joe0606
i have never used a boost valve. but u need to match your boost levels to your fueling. i would take it for a set up mate. do your no what spec your car is at. whats been done to it.
joe
Old Oct 20, 2010 | 07:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If your new to RST's then the very best thing you can do is spend £150 on a tune up at your local RS specialist mate.
You'll come away with more power, a list of things you can upgrade to go even further, and probably a list of things that need fixing now too! lol
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
