3dr wont start
Old Oct 20, 2010 | 07:23 PM
turblower's Avatar
turblower
Default 3dr wont start
hi peeps,drove my 3dr in to my garage runing yesterday,i undone the battery connection,
i went to start it today an it wont start now,it has plenty of spark but i cannot hear the fuel pump swithching on,is their like a safe switch for the fuel pump on the 3dr?
much appriciated if you guys could help us out...thanks
Old Oct 20, 2010 | 07:35 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
rst's have a fuel cut offs in the boot/rear seat so could be same on the 3dr also do ya have a factory fitted immoboliser
Old Oct 20, 2010 | 07:41 PM
turblower's Avatar
turblower
i have a quick check in the boot an couldnt see nout....
Old Oct 20, 2010 | 07:54 PM
gingerturbo
mmm somethings defently clicked on when ya remove the battery ive known factory fittle immoblisers to come on, have ya kicked or knocked the pink relay
Cossy Mike's Avatar
Cossy Mike
On a Sapphire it's under the spare wheel. It's a black relay thingy with a push switch on it mounted inside a metal bracket riveted to the floor.
try that, just push switch.
Old Oct 20, 2010 | 07:55 PM
There is a fuel pump cut off(inertia) switch under the spare wheel, it has a white square button that pops up if tripped(turned off) simply depress button to switch back on.
Old Oct 20, 2010 | 07:57 PM
BEN FRST's Avatar
BEN FRST
if not check the fuel pump fuse under the dash on the passenger side
Old Oct 20, 2010 | 08:24 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
I dont think 3drs have a fuel cut switch, well mine didnt anyway.
Old Oct 20, 2010 | 08:51 PM
stickertone's Avatar
stickertone
have you definatly connected all the wires back on the battery? its easy to miss one off.....
Old Oct 20, 2010 | 08:54 PM
phil_rs's Avatar
phil_rs
yam yammer
That's weird because I've had about 20 Escort RST's and have never come across a fuel cut off switch. Escort xr3i efi's did though
Old Oct 20, 2010 | 08:58 PM
jason_nike's Avatar
jason_nike
Clifford alarm by any chance???
Old Oct 20, 2010 | 09:04 PM
BRAMMER's Avatar
BRAMMER
Second that it's the first thing i look at if the pump isn't priming
Or it may just be one of the million wires that are normally on the battery
Old Oct 20, 2010 | 09:47 PM
AndyPen's Avatar
AndyPen
My relay came unfixed and one day a fuse fell onto the floor and we stopped!!!! At least i was certain that it was that fuse.
And as said - 3 drs did not have the cut out like the saffs do.
Old Oct 20, 2010 | 10:25 PM
barry bigfin's Avatar
barry bigfin
Durham RSOC
There is two yellow relays on the passenger side. I you look under the glove box you should be able to see them. It could be one of them at fault. You can take one out ov your fuse box and test them one at a time.
Old Oct 21, 2010 | 12:32 PM
martysmartie's Avatar
martysmartie
First off check the obvious battery connections as the majority of pumps have been rewired direct from battery you may have missed that wire hence no pump.
What sort of alarm is it? It seems unlikely to me to be a wiring problem etc as it's only since you have D/C the battery (Unless by pure coincidence) It could be basic single point immobilization on the fuel pump.
In any case check the relays etc as said anyway, bypass the relay as a test to see if the pump runs.
Martin
Old Oct 21, 2010 | 02:38 PM
turblower's Avatar
turblower
ohh cheers for the help guys,i will have a good luck at it when the weather gets better....
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
