external wastegate connection?
hello everybody,can anyone tell me the correct connection with bleed vavle for this wastegate, please? thanks a lot.
hese some pics from my wastegate.
I'm no expert like, but if you want to plumb a bleed valve in, isn't it similar to an actuator set up.? Take the outlet from your inlet turbine..pipe into bleed valve the from bleed valve to wastegate so you can tinker with the pressure.
What controls the wastegate normally, and how is it adjusted..different spring rates.?
Mark RS
Oct 12, 2015 06:01 AM
