wiring diagram pump
Old Oct 20, 2010 | 04:07 PM
oadamo's Avatar
oadamo
Default wiring diagram pump
hi iam having a problem with my focus not starting and it seems to be cutting the fuel. it only happens ever now and then but the one time it didnt start i pulled the fuel pipe off and didnt get any fuel. have you got a wiring diagram for the full fuel pump diagram with relays or any ideas whats could be wrong.
adam
Old Oct 20, 2010 | 07:05 PM
bonnerworld's Avatar
bonnerworld
mine had a similar problem,
swap some relays about in the under bonnet fuse box, mine had a faulty main on relay (large grey ones) swapped it with the rear screen relay and all worked ok
otherwise it goes
battery----main on relay----fuelpump relay----inertia fuel cut off----pump
hope this helps
Old Oct 20, 2010 | 07:51 PM
oadamo's Avatar
oadamo
otherwise it goes
hope this helps
thanks great help ill have a look on the bay and buy some spare relays then when it happens again i will swap the lot to see if it sorts it, its doing my head in now lol.
Old Oct 22, 2010 | 03:12 PM
oadamo's Avatar
oadamo
after testing the relays and pump all seemed ok and was getting a 12v feed ok, so i had to take the tank off to find out if it was the pump. i was just hoping it was a relay lol. this is what i found thank fuk the car didt go up ion flames. so ive ordered a new pump so i hope it sorts the problem out.
adam
Old Oct 22, 2010 | 03:17 PM
bonnerworld
yup, that will do it, good thing you caught that when you did
bit of a pain having to drop the tank to change the pump though, posibly the one and only thing that is good about peugeots, they have an access pannel under the seat to remove it that way (know what i will do if i need to change a pump)
should be good when its all sorted and at least you found a proper problem
Ian
Old Oct 22, 2010 | 03:26 PM
oadamo's Avatar
oadamo
Ian
thanks for your help it was one of them problems when evertime i got into the car to go to somewhere important the fuker wouldnt start. i think i would of set it on fire in the end if the pump didnt lol.
adam
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
155lee
Oct 24, 2015 11:11 AM
THE RADMAN
Sep 19, 2015 12:57 PM
Fudgey
Sep 17, 2015 01:06 PM
ward1174
Sep 12, 2015 03:34 AM
