Am I right to be concerned - TV install
Old Oct 20, 2010 | 01:35 PM
Oranoco's Avatar
Oranoco
Default Am I right to be concerned - TV install
At work we're having a new control room built. As part of this 3 46" Samsung LCD TV's have been mounted on the wall. One of these sets has been mounted 50mm under a wall mounted air conditioning unit. This is ringing alarm bells with me.
Anybody clued up on such things that can advise?
Old Oct 20, 2010 | 01:49 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
My non expert opinion would scream health and safety hazard!!
Old Oct 20, 2010 | 02:02 PM
StephenC's Avatar
StephenC
..BS Motorsport..
wouldnt worry, when it leaks and blows that tv up say it took the other two with it, keep one and ebay one, job done.
Old Oct 20, 2010 | 02:07 PM
dojj's Avatar
dojj
Resident Wrestling Legend
It shouldn't be a problem when everything is workig right, but if there is a problem then things are going to get fucked up. Either move the telly or the ac unit, boarding it up in the middle won't stop issues like leakage from fucking the telly up
Old Oct 20, 2010 | 02:46 PM
cjwood555's Avatar
cjwood555
Was there anywhere else to put it?
It's not great if the ac is discharging down onto the display as there'll be a big temperature gradient inside which could cause condensation. That and the potential for leaks, of course. But if that's the only place they could go, or where the client (your boss, presumably) wanted them, then so be it. If you're particularly worried you could install a gutter of some kind below the AC unit.
Also are these actually TV's or proper commercial displays?
Chris
Old Oct 20, 2010 | 04:49 PM
danneth's Avatar
danneth
TORQUE!
with every con theres a pro in this case once an accident occurs you can go and get a panasonic.
Old Oct 20, 2010 | 05:01 PM
steves24V's's Avatar
steves24V's
lol
our air con unit at work has a little pump in it to pump the water away as in it has to go up hill, this pump failed one day and we had a pool of water in the shop. hope the same doesnt happen to yours.
Old Oct 20, 2010 | 05:03 PM
focusv8's Avatar
focusv8
The condensate pump in the A/C unit will fail at some time and the drip tray will overflow so the screen is doomed.
It's only a problem for the TV, it's not a problem or safety risk for you.
Old Oct 20, 2010 | 05:12 PM
AJC's Avatar
AJC
numptys
Old Oct 20, 2010 | 05:14 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
pff we have air con in every room, if they all leaked they would wreck every computer in the company
we dont go thru many computers
also the ac units dont 'spray' directly down, they come out at about 45 degs from the wall as cold sinks the air would circulate upwards where the telly is
ask yourself when the last time the ac unit went tits up, then dont worry about it
Old Oct 20, 2010 | 05:16 PM
Ginge's Avatar
Ginge
www.virtualseason.net
Who had the bright idea to mount it there?!
It's a time bomb..
Ginge
Old Oct 20, 2010 | 07:45 PM
focusv8's Avatar
focusv8
Ask a refrigeration engineer how many times he gets calls to leaking A/C units, then worry.
Old Oct 20, 2010 | 07:49 PM
RichieST's Avatar
RichieST
You get 3 x 46" tellys to watch, A/C to keep you cool in the summer, and you're complaining it might be a Health and safety hazard? I'd keep schtum if I were you
Old Oct 20, 2010 | 07:52 PM
focusv8's Avatar
focusv8
And I bet the screens have each got around 32 different channels on at the same time??
Old Oct 20, 2010 | 07:57 PM
1.9 xr2 on 40's
st170 breaking
lol thats like asking me if aerials are shit, yeah every day i am fixing them, not to say that most have been there 40 years ! lol
farkin hell
Old Oct 20, 2010 | 08:05 PM
focusv8's Avatar
focusv8
farkin hell
I don't repair A/c units, but I repair other things in buildings that have loads of them.
I see plenty of them leaking especially when it's hot outside.
And none of them are mounted over anything electrical or anything else they could do serious damage to, unless you count food and people.
Old Oct 20, 2010 | 08:07 PM
danneth's Avatar
danneth
TORQUE!
Im also a sparky, and failing A/C is common imo
Old Oct 20, 2010 | 08:10 PM
LHD220Turbo's Avatar
LHD220Turbo
A/c units do leak; faulty pump is one reason; another is if the temp has been set to low which the A/C unit cannot achieve; especially if its warm outside
JoeRS22's Avatar
JoeRS22
put a reliable tank pump under the a/c unit to take the condense and should be ok
Old Oct 20, 2010 | 08:18 PM
Jim Galbally's Avatar
Jim Galbally
if the AC unit has a drip tray with leak detection system also installed you might get away with it
gingeRS
17
Oct 2, 2015 09:42 AM
Bailes1992
Sep 19, 2015 02:17 PM
