went out to the garage today :)
i think i need to get the polish on the job, im not good at this bufty shit ... any1 fancy coming to clean the poor thing, i have a £5 in my pocket lol
Just in need of some nice manifolds
I will pull it out in a few days (weeks) to get a few photos AND i miss my th2's!!!
its 1600cvh forged pistons steel rods / worked crank and flywheel
big valve stage 3 head with proper large ports
ported inlet
airtech manifold/ rad / fmic/ breather /
gotech mfi with custom loom (might be fitting megasquirt)
t34 .48 nms stage3 spec hybrid turbo
power engineering cam (changing to newman) and piper pully
cts stage2+ ib5 with quiafe atb
ap paddle clutch / vibratechnics mounts / b&m quickshift
grey 403s
but im abit pissed off because my management is not the best you can get and ive been told that i need the pro x to run 2bar+ boost..... although it is possible by modding it to fit a external map sensor but im gunna sell now and upgrade
so im thinking of selling the gotech which is rated to 22psi boost so with a stage 3 t3 would be nearly 240/250bhp..... .....
ported inlet
grey 403s
thanks gus its ok to be honest i just went out and brought a minter then just got rid of the standard bits and put the new engine in .... but i realy want some manifolds to finish the spec and some new wheels and a newman cam set up......
and for when karlos sees this im thinking about the ms conversion .....
and check out the missus new car....
https://passionford.com/forum/genera...ml#post5140675
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
