Cosworth Racing Pistons
Old Jan 26, 2005 | 10:21 AM
Sheldy's Avatar
Sheldy
Default Cosworth Racing Pistons
Has anyone on here had any experience using these and are they worth the premium over the usual low-comp mahle jobs.
Old Jan 26, 2005 | 05:34 PM
Weeksy's Avatar
Weeksy
Hi dude,
I've got some in mine matey.
They are a bit noisey from cold due to the piston / bore clearance needed, but I really just bough them for peace of mind! They are 7.2:1, but with my head havbing been machined, it's about 7.5.
It's up to you matey, they are renowned to be one of the best- you pays your money, you takes your choice!
Regards
Weeksy
Old Jan 27, 2005 | 12:21 AM
RSCosworth's Avatar
RSCosworth
I've seen ppl recommend them for use in supras etc too...
Old Jan 27, 2005 | 08:03 AM
Sheldy's Avatar
Sheldy
I'd heard their good so I thinks i'll pay the the extra I don't really want to be replacing ANOTHER set of pistons in six months time!
Old Jan 27, 2005 | 08:05 AM
Weeksy's Avatar
Weeksy
I don't think you 'll be doing that unless something disastrous goes wrong!!
What spec are you planning to run?
Old Jan 27, 2005 | 10:25 AM
swerv's Avatar
swerv
as you will hear in the futrue no doubt, If there is something wrong with your fuelling it dosnt matter if you have mahle or cosworth pistons in there they will both melt if things are not right!!
The cosworth racing piston is the better quality and they come 7.2:1 already , but if you have melted mahles and you havnt fixed the problem then you will melt these
Old Jan 27, 2005 | 10:33 AM
Weeksy's Avatar
Weeksy
True True
Old Jan 27, 2005 | 09:06 PM
Sheldy's Avatar
Sheldy
was running standard compression with 1.8 bar max boost on greens.
took the head off at the weekend and found number 2 piston had melted and part of the bore. I realise that perhaps this was a bit too much boost for the spec but this is the way the previous owner had set it up.
so i plan to rebuild using lower compresion say 7.2:1, BD10's, flowed head and fuelling with greys and a live map chip.
Old Jan 27, 2005 | 09:27 PM
boost mad's Avatar
boost mad
just to let u no, bd10's are laggy ( if used on the exhaust side)
Old Jan 28, 2005 | 07:04 AM
Weeksy's Avatar
Weeksy
I run 7.5, greys, ported head and manifolds, 2 bar of boost and bd14's on both sides, and think that it's ok.
I know it's not the most up to date set up, but it seems to work ok for me!!
SmudgerByName
52
Jul 28, 2016 06:14 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
KW-rscos
11
Aug 31, 2015 01:51 PM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
