rear chassis legs
hi all i'm in need of some rear chassis legs but on ordering i'v noticed theres 2 types so i'm just wandering witch one i need
http://www.auto-paints4u.co.uk/media...0-27-354_4.gif
http://www.auto-paints4u.co.uk/media...0-27-358_4.gif
i can see that the one hasnt got the cup for the spring was just thinking are you ment to use the old cup you take off the car or is the one with out ment for an escort van cheers.
you can use either its up to you i will be using the ones without cups on mine as i am running coilovers so the spring is no longer attached to the chassis
the van ones are different as they run leaf springs on the rear
also the ones with the cups usually come with the rear tie bar mounts on as well
if they are for an orion they will be longer,and i think escort combis may be a different shape as they have a flat floor.a guy i know did the chassis legs on his combi and had to alter something due to the shape of the floor.the 55cwt vans have leafs.
yeah think i will get the ones without the cups as 1.there cheaper lol 2.my tie bar ends are good only thing is now i'm not sure what cups to getting as theres to types.
http://www.auto-paints4u.co.uk/body-...c-w-plate.html
http://www.auto-paints4u.co.uk/body-...ring-seat.html
155lee
Sep 6, 2016 11:10 AM
The Enigma
Sep 12, 2015 10:12 PM
