gearbox question
Old Oct 16, 2010 | 09:27 PM
1strst's Avatar
1strst
Default gearbox question
just found this on the bay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
my question is wil a rs lsd and drive shafts fit straight in or will i need different ones?
Old Oct 16, 2010 | 09:49 PM
conor.rst's Avatar
conor.rst
Direct fit as far as im aware. why would you want that box ?
Old Oct 16, 2010 | 10:03 PM
1strst's Avatar
1strst
just looking if im honest it wouldnt be a diesel box i would get probly a 1.8 escort box and rebuild it with a lsd
Old Oct 16, 2010 | 10:06 PM
conor.rst's Avatar
conor.rst
Oh whats wrong with just a standard s2 box?
Old Oct 16, 2010 | 10:13 PM
1strst's Avatar
1strst
from what i have read these seem a little stronger and easier to get hold of than a s2 box
Old Oct 16, 2010 | 10:20 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Nothing wrong with diesel box.good luck on your find.
conor.rst's Avatar
conor.rst
yeah i think thats just aload of bull from what ive heard. i put a s1box on mine Soo much better
Old Oct 16, 2010 | 10:33 PM
1strst's Avatar
1strst
i thought the bearings were bigger on the ib5 compared to the bc box
Old Oct 16, 2010 | 10:34 PM
1strst's Avatar
1strst
not sure if thats sarcasm?
Old Oct 16, 2010 | 10:36 PM
boothy's Avatar
boothy
Think hes saying that there aint many deisel boxes left
Old Oct 16, 2010 | 10:41 PM
botters's Avatar
botters
competant bodger
diesel boxes are still weak just have different ratios that are not really suited to an rs turbo, you would be better off with a 1.7 puma box these are a tough cheap box
Old Oct 16, 2010 | 10:46 PM
rsmark86's Avatar
rsmark86
fit a ib5 mate and either a escort 1600 16v zetec one for alonger gearing or a revvy one like above off a puma of ka sport then use a puma linkage for a much better feel
Old Oct 16, 2010 | 10:51 PM
1strst's Avatar
1strst
just had a look at the puma box is it just a straight swap aswell? and is the starter on the front as all the pics dont show where the starter is
Old Oct 16, 2010 | 11:33 PM
essexRSTSouthend
No i werent at all.i run a diesel box and happy with it.love the ratios.
Old Oct 17, 2010 | 05:48 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Puma is rear starter I think.
Old Oct 17, 2010 | 08:43 AM
1strst's Avatar
1strst
http://cgi.ebay.co.uk/1999-FORD-PUMA...item4aa2fbfebf
looks like a front starter and hydraulic
Old Oct 17, 2010 | 09:46 AM
craig rst kid's Avatar
craig rst kid
how did you get on with your engine rebuild mate
Old Oct 17, 2010 | 09:50 AM
1strst's Avatar
1strst
still in the process lol evry time i get close i think before it put it together i will just do ?????????????????? so i think it should be ready for my eldest sons first car..................... hes 6
Old Oct 17, 2010 | 10:15 AM
rsmark86's Avatar
rsmark86
speak to karlos if its a s2 he done a thread on how to fit a ib5 into a s2 from a ka sport .... but they only bolt straight into a s1 but its only small mods needed and karlos done a thread on it
Old Oct 17, 2010 | 10:18 AM
AladdinBlown4x4's Avatar
AladdinBlown4x4
Petrol burner
If you're really running 231 BHP then any B5 box wont last long,better with the MTX75,box,can handle all the torque a cvh will ever produce,plus you can get a smooth engagement on reverse.
Old Oct 17, 2010 | 10:57 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It is but it's at the top not the bottom, would hit the turbo
Old Oct 17, 2010 | 11:02 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah we all know this but it requires custom shafts, cutting the inner wing, and custom mounts which makes the price far far greater than dropping a IB5 in, unless you can do all the fab yourself including shafts, and it's not hydraulic.
Old Oct 17, 2010 | 12:45 PM
1strst's Avatar
1strst
shit
ka box then is it a straight forward conversion karlos? other than the mounting the drive shafts fit straight in ?
Old Oct 17, 2010 | 12:55 PM
zippyobrien's Avatar
zippyobrien
Ul need to machine the crown wheel to fit over the larger LSD. And u can only put a 8 bolt diff from a s2 in a ib5
Lee
Old Oct 17, 2010 | 01:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
shit
Yeah drive shafts fit straight in, look here mate https://passionford.com/forum/ford-e...x-fitting.html
Lee
Do you? I thought an RST LSD will drop straight in, just need to fit the larger IB5 bearings
Old Oct 17, 2010 | 02:04 PM
craig rst kid
still in the process lol evry time i get close i think before it put it together i will just do ?????????????????? so i think it should be ready for my eldest sonls first car..................... hes 6
lmao its worth the w8 tough m8 do yuou think youll be ready for central day
Old Oct 17, 2010 | 02:21 PM
1strst's Avatar
1strst
i hope so i want the front end finished around christmas and then start the back end
Old Oct 17, 2010 | 05:35 PM
zippyobrien
Nope s2 diff is slightly larger that the open diff. Have to file a bit of the internal casing to
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
